Sliders Install
#2541907
08/27/18 10:30 AM
08/27/18 10:30 AM
Posts: 192 Gravataí, RS, Brazil
360tripleblack77
I've finished my own homemade sliders to install on My car. At same time I'm changing from OEM leaf spring to Calvert Monoleafs...
So I couldn't check the ride height with the new spring before install sliders... I've measured with the car in jack stands and installed sliders. Attached a picture of the sliders installed. The car was in the jack stands with que rear tires and rear suspension unloaded.
My question is: I've a travel enough when the car will launch?
'77 Brazilian Dodge Charger R/T - Street Car Footbrake, Pump Gas, SB Mopar 360" N/A 3300lbs, Leaf Spring + Assassin Bars Best 1/8 mile ET 1.50 60' / 4.31 330' / 6.73@102.54mph
Re: Sliders Install
[Re: 360tripleblack77]
#2541912
08/27/18 10:41 AM
08/27/18 10:41 AM
Posts: 1,260 New Mexico
Adobedude
New Mexico
Slider was installed too far forward, you want the eye behind the center point of the slider at rest, almost the reverse of what you have.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
Re: Sliders Install
[Re: Adobedude]
#2541919
08/27/18 11:00 AM
08/27/18 11:00 AM
360tripleblack77
Do you think that I'll have problem of the slider hit on the front at launch?
Re: Sliders Install
#2541927
08/27/18 11:09 AM
08/27/18 11:09 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I always tack the slider on so I can check the movement when its on the ground EDIT a lot of springs will be different due to the amount of flex they have
Re: Sliders Install
[Re: MR_P_BODY]
#2541932
08/27/18 11:17 AM
08/27/18 11:17 AM
360tripleblack77
When I put the car at ride height the slider position was on the middle. So I will install my GoPro the make a movie during a Street test to check the slider behavior on the launch.
I'll have race on the weekend So I need to check this quicky.. lol
Re: Sliders Install
#2541936
08/27/18 11:20 AM
08/27/18 11:20 AM
Posts: 625 Indianapolis In. usa
Quickrunner
You want the bearing close to the rear of the slider at rest with full weight on it, maybe an inch from the back to give it travel to the front on launch
05 Ram 1500 Daytona package 71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
Re: Sliders Install
#2541942
08/27/18 11:31 AM
08/27/18 11:31 AM
MR_P_BODY
If your near the middle now you need to move them forward... just dont let them hit the back side.. you dont need much clearance on most springs
Re: Sliders Install
[Re: Adobedude]
#2541958
08/27/18 11:52 AM
08/27/18 11:52 AM
360tripleblack77
Thanks Man!!! Based on your video I can see that the sliders don't has so long moviment. I shouldn't have any problem with them. I really appreciate your help.
Re: Sliders Install
[Re: hemi-itis]
#2541961
08/27/18 11:58 AM
08/27/18 11:58 AM
360tripleblack77
I really wouldn't like to rework because I welded them in a lot of points in body. lol
Re: Sliders Install
#2542176
08/27/18 09:31 PM
08/27/18 09:31 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
I really wouldn't like to rework because I welded them in a lot of points in body. lol . Can you get her down on the ground and give us a picture of the slider location at right height
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
Re: Sliders Install
[Re: WHITEDART]
#2542480
08/28/18 01:56 PM
08/28/18 01:56 PM
360tripleblack77
Nice!! I'll do that tonight and post a picture here tomorrow.
Thanks Shiloh
Re: Sliders Install
[Re: WHITEDART]
#2543152
08/29/18 05:59 PM
08/29/18 05:59 PM
360tripleblack77
This pic is on ride height...
Re: Sliders Install
#2543158
08/29/18 06:15 PM
08/29/18 06:15 PM
Posts: 252 southeast ky
mills.mopar
southeast ky
According to what I've been told, the slider should be moved forward. But if you have a GoPro I'd run it and see if it bottoms out... Sounds like you already have it welded in place. Jeff.
If you love it lube it
68 dart 37 dodge coupe 71 challenger
