Sliders Install #2541907
08/27/18 10:30 AM
08/27/18 10:30 AM
Gravataí, RS, Brazil
360tripleblack77 Offline OP
I've finished my own homemade sliders to install on My car. At same time I'm changing from OEM leaf spring to Calvert Monoleafs...
So I couldn't check the ride height with the new spring before install sliders... I've measured with the car in jack stands and installed sliders. Attached a picture of the sliders installed. The car was in the jack stands with que rear tires and rear suspension unloaded.
My question is: I've a travel enough when the car will launch?
'77 Brazilian Dodge Charger R/T - Street Car
Footbrake, Pump Gas, SB Mopar 360" N/A
3300lbs, Leaf Spring + Assassin Bars
Best 1/8 mile ET
1.50 60' / 4.31 330' / 6.73@102.54mph
Re: Sliders Install [Re: 360tripleblack77] #2541912
08/27/18 10:41 AM
08/27/18 10:41 AM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Slider was installed too far forward, you want the eye behind the center point of the slider at rest, almost the reverse of what you have.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Sliders Install [Re: Adobedude] #2541919
08/27/18 11:00 AM
08/27/18 11:00 AM
Do you think that I'll have problem of the slider hit on the front at launch?
Best 1/8 mile ET
Re: Sliders Install [Re: 360tripleblack77] #2541927
08/27/18 11:09 AM
08/27/18 11:09 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I always tack the slider on so I can check the
movement when its on the ground
EDIT
a lot of springs will be different due to the
amount of flex they have
wave
Re: Sliders Install [Re: 360tripleblack77] #2541931
08/27/18 11:16 AM
08/27/18 11:16 AM
Seminole County FL to Plymouth...
Barry70GTX Offline
Barry70GTX  Offline
It's going to be close. Put some grease on the slider, make a couple of hits and see what you have.
NMCA NSS 67 Coronet
Re: Sliders Install [Re: MR_P_BODY] #2541932
08/27/18 11:17 AM
08/27/18 11:17 AM
When I put the car at ride height the slider position was on the middle. So I will install my GoPro the make a movie during a Street test to check the slider behavior on the launch.
I'll have race on the weekend So I need to check this quicky.. lol
Best 1/8 mile ET
Re: Sliders Install [Re: 360tripleblack77] #2541936
08/27/18 11:20 AM
08/27/18 11:20 AM
Indianapolis In. usa
Quickrunner Offline
Quickrunner  Offline
You want the bearing close to the rear of the slider at rest with full weight on it, maybe an inch from the back to give it travel to the front on launch
05 Ram 1500 Daytona package
71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
Re: Sliders Install [Re: 360tripleblack77] #2541942
08/27/18 11:31 AM
08/27/18 11:31 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If your near the middle now you need to move
them forward... just dont let them hit the back
side.. you dont need much clearance on most springs
wave
Re: Sliders Install [Re: 360tripleblack77] #2541945
08/27/18 11:35 AM
08/27/18 11:35 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Perfect where it is!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Sliders Install [Re: 360tripleblack77] #2541952
08/27/18 11:44 AM
08/27/18 11:44 AM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
Re: Sliders Install [Re: 360tripleblack77] #2541953
08/27/18 11:45 AM
08/27/18 11:45 AM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
Re: Sliders Install [Re: Adobedude] #2541958
08/27/18 11:52 AM
08/27/18 11:52 AM
Thanks Man!!! Based on your video I can see that the sliders don't has so long moviment. I shouldn't have any problem with them. I really appreciate your help.
Best 1/8 mile ET
Re: Sliders Install [Re: hemi-itis] #2541961
08/27/18 11:58 AM
08/27/18 11:58 AM
I really wouldn't like to rework because I welded them in a lot of points in body. lol
Best 1/8 mile ET
Re: Sliders Install [Re: 360tripleblack77] #2541962
08/27/18 12:04 PM
08/27/18 12:04 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Calvert says:
"At ride height the center of the rear spring eye should be between 60-75 percent back"
Good luck!
Re: Sliders Install [Re: 360tripleblack77] #2542176
08/27/18 09:31 PM
08/27/18 09:31 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
. Can you get her down on the ground and give us a picture of the slider location at right height
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Sliders Install [Re: 360tripleblack77] #2542185
08/27/18 09:48 PM
08/27/18 09:48 PM
P
Porter67 Offline
Porter67  Offline
P
As mentioned id get it to full weight and sit it down, and your springs will settle a bit.
Id do all that and although your not going to be to the likes of many you may be ok.
Im a bit the other way with a full cell and if im running two bottles on my street racer, but if I run only 5 gallons im about 85% back and have never had an issue.
I set my whole car up with still using the oem shackles so I positioned the sliders eye where the shackle eye would of been and had to make no other alterations
Re: Sliders Install [Re: 360tripleblack77] #2542208
08/27/18 10:45 PM
08/27/18 10:45 PM
P
Porter67 Offline
Porter67  Offline
P
If you need more travel.......
https://www.youtube.com/watch?v=MavuKdWb9Ws
Re: Sliders Install [Re: WHITEDART] #2542480
08/28/18 01:56 PM
08/28/18 01:56 PM
Nice!! I'll do that tonight and post a picture here tomorrow.
Thanks Shiloh
Best 1/8 mile ET
Re: Sliders Install [Re: WHITEDART] #2543152
08/29/18 05:59 PM
08/29/18 05:59 PM
This pic is on ride height...
Best 1/8 mile ET
Re: Sliders Install [Re: 360tripleblack77] #2543158
08/29/18 06:15 PM
08/29/18 06:15 PM
southeast ky
mills.mopar Offline
mills.mopar  Offline
southeast ky
According to what I've been told, the slider should be moved forward. But if you have a GoPro I'd run it and see if it bottoms out... Sounds like you already have it welded in place.
Jeff.
If you love it lube it
68 dart
37 dodge coupe
71 challenger
