70RR Airgrabber switch and solenoid...? #2537923
08/17/18 11:09 PM
08/17/18 11:09 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
so pulled by dash out to repair some wiring issues...and dont want to do it again... how can i test the switch ans solenoid before I reinstall....??
The wire in the solenoid is already iffiy.... who sells these..??
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: 70RR Airgrabber switch and solenoid...? [Re: JMCFAN] #2537946
08/18/18 12:23 AM
08/18/18 12:23 AM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
Blow through the hose with your mouth to make sure it is open. Apply current to the green wire. Making sure to ground the solenoid to make a complete circuit. Listen for a "click" in the solenoid. Blow into the hose to see if it blocked off the air flow. I hope I have it the correct direction.
Re: 70RR Airgrabber switch and solenoid...? [Re: 70HemiGTX] #2537949
08/18/18 12:32 AM
08/18/18 12:32 AM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
P.G. Classic Reproduction
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: 70RR Airgrabber switch and solenoid...? [Re: JMCFAN] #2542169
08/27/18 09:21 PM
08/27/18 09:21 PM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
Be careful of reproduction switches out currently. Have two friend who put air grabber on their cars and went through crap trying to find ones that worked properly. One guy had 6 repro ones all fail til he got a nos one and it worked perfectly.
Re: 70RR Airgrabber switch and solenoid...? [Re: migsBIG] #2542408
08/28/18 12:03 PM
08/28/18 12:03 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Any way to test the switch?
Re: 70RR Airgrabber switch and solenoid...? [Re: JMCFAN] #2543244
08/29/18 10:49 PM
08/29/18 10:49 PM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
I use a hand pump and two vacuum gauges.
All switches leak you want one that leaks the least.
Most of the time the nubs on the back are broken. They can be repaired. The aftermarket switches look good but don't have the quality like the originals. Most of them don't work properly. If you have one that does but the nubs get broken it can be repaired.
In this video the first switch as a vacuum leak at the nubs that is quite large.
The second switch has a leak but it is much less, repaired nubs.
https://youtu.be/oCmqnw0Y6Fg
