I use a hand pump and two vacuum gauges.
All switches leak you want one that leaks the least.
Most of the time the nubs on the back are broken. They can be repaired. The aftermarket switches look good but don't have the quality like the originals. Most of them don't work properly. If you have one that does but the nubs get broken it can be repaired.
In this video the first switch as a vacuum leak at the nubs that is quite large.
The second switch has a leak but it is much less, repaired nubs.
https://youtu.be/oCmqnw0Y6Fg
