Re: What will it run? [Re: RRandP92] #2542024
08/27/18 02:47 PM
08/27/18 02:47 PM
IL
Dart451 Offline
Dart451  Offline
IL
Guessing 10.3 if this is first time out with combo. will go 9's with some laps on it
Re: What will it run? [Re: RRandP92] #2542057
08/27/18 03:34 PM
08/27/18 03:34 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Originally Posted By RRandP92
69 dart 3225lbs race weight,caltracs,520ci,trick flow 270, .650 lift 265ish duration solid roller, 11.5:1 compression,indy intake,1050 dominator,727,8in converter specd by ultimate, 3.70 rear gear,325/50 radial. Let's here it. Hopefully get to make some test hits Friday.
Any on board data or at least a wide band...........
Re: What will it run? [Re: RRandP92] #2542058
08/27/18 03:39 PM
08/27/18 03:39 PM
an8sec70cuda Offline
I agree w/ the 9.80s when sorted out. I know I went 10.40s at 129 mph at 3700 lbs w/ less motor than you have.
The radials will work just fine too.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: What will it run? [Re: RRandP92] #2542287
08/28/18 01:03 AM
08/28/18 01:03 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I agree with 9.80's. Ron
Re: What will it run? [Re: Thumperdart] #2542289
08/28/18 01:12 AM
08/28/18 01:12 AM
TN
RRandP92 Offline OP
RRandP92  Offline OP
TN
I do have a wide band on it will need to spend some time reading the plugs and getting the carb dialed in.
Re: What will it run? [Re: RRandP92] #2551354
09/18/18 01:18 AM
09/18/18 01:18 AM
TN
RRandP92 Offline OP
RRandP92  Offline OP
TN
Well dragweek was cut short for us.We headed for Atlanta with 1 and a half 1/8th mile passes about 60miles on the car. First 1/8th mile pass ran the car about 400ft through 1st and 2nd. The car carried the wheels about 12in 40ft out leaving at 2500rpm. The timing system was messed up and did not get a ticket. 2nd pass car hooked then spun bad and ran 6.75 at 102. Had some issues with the valve cover vents blowing oil b/c no baffle so we loaded it up. Made some baffles and put some miles on it tuning the carb for cruise. Everything was good to go so we loaded up. We made the first test pass on Sunday after the rain came through. The car hooked good and ran through the 1/4 with no issues but the front half didn't feel as strong as the test pass I had made. Get to the ticket shack and no ticket during to water in the beams! So we pull the air cleaner bump the timing to 34degrees from 32 and make it back to the lanes just before last call. The car was lazy and did not pull hard through the lights. Went a 10.76 at 122mph. Back to the pits pull the valve covers to check lash and everything is spot on. Start the car let it run for about 2 mins and it locks up as tight as can be. Car had 25lbs of oil pressure idling at 1300rpm. Let the motor cool down and it is all you can do to turn the engine over with breaker bar. Pull the plugs and valve covers, no damaged plugs or push rods.
We now know it's in the bottom end. Looks like the main and rod clearances we all too tight spun #3rod bearing and 1,2,4 were soon to follow.
Re: What will it run? [Re: RRandP92] #2551379
09/18/18 04:56 AM
09/18/18 04:56 AM
gregsdart Offline
gregsdart  Offline
Bummer. Sorry to hear, but glad you caught it before it ventilated the block and worse. Are you sure it was only a clearance problem?
Re: What will it run? [Re: RRandP92] #2551464
09/18/18 12:22 PM
09/18/18 12:22 PM
TN
RRandP92 Offline OP
RRandP92  Offline OP
TN
Based on what checking the crank so far it looks like a clearance only issue. Running a mellings high volume pump and milodon single line static pick up in a 6qt hemi pan for ground clearance. Car had 75-80lbs oil pressure through the traps. I have a 7qt pan but it hangs very low.
Re: What will it run? [Re: RRandP92] #2551473
09/18/18 12:47 PM
09/18/18 12:47 PM
Mt Morris Michigan
mopar dave Online content
mopar dave  Online Content
Mt Morris Michigan
Wow! Sorry to hear as my combo is almost same as yours. Would guess 10.0 to 10.10. What were your bearing clearances?
Re: What will it run? [Re: RRandP92] #2551531
09/18/18 03:03 PM
09/18/18 03:03 PM
TN
RRandP92 Offline OP
RRandP92  Offline OP
TN
The good throws were at .0015 on the rods. Should have checked them over.
Re: What will it run? [Re: RRandP92] #2551550
09/18/18 03:44 PM
09/18/18 03:44 PM
Mt Morris Michigan
Mt Morris Michigan
Yeah, thats a little tight.
Re: What will it run? [Re: RRandP92] #2552031
09/19/18 07:00 PM
09/19/18 07:00 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'd hope in the 9's
Coming soon!!!!
