What will it run? #2541583
08/26/18 03:07 PM
08/26/18 03:07 PM
TN
RRandP92 Offline OP
RRandP92  Offline OP
TN
69 dart 3225lbs race weight,caltracs,520ci,trick flow 270, .650 lift 265ish duration solid roller, 11.5:1 compression,indy intake,1050 dominator,727,8in converter specd by ultimate, 3.70 rear gear,325/50 radial. Let's here it. Hopefully get to make some test hits Friday.
Re: What will it run? [Re: RRandP92] #2541586
08/26/18 03:13 PM
08/26/18 03:13 PM
CO
crankn101 Offline
crankn101  Offline
CO
For the record, I know nothing and Im just guessing for fun...
10.8 when its dialed in
Re: What will it run? [Re: RRandP92] #2541587
08/26/18 03:14 PM
08/26/18 03:14 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
10.20’s to 30’s
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: What will it run? [Re: RRandP92] #2541593
08/26/18 03:30 PM
08/26/18 03:30 PM
UK
rb446 Offline
rb446  Offline
UK
I'll take a guess at your fwhp to be 690, if your chassis is up to it and its all running on song your ticket could look something like this with the tyre height@28"?+3.7's>
60 Foot E.T. : 1.35
1/8 Mile E.T. : 6.15
1/8 Mile Trap Speed : 110.61
1/4 Mile E.T. : 9.74
1/4 Mile Trap Speed : 138
1/4 Mile Trap RPM : 6,114+slip
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: What will it run? [Re: RRandP92] #2541596
08/26/18 03:32 PM
08/26/18 03:32 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
9.80 if it's sorted
Getting old just means you were smarter than some and luckier than others.
Re: What will it run? [Re: RRandP92] #2541644
08/26/18 05:36 PM
08/26/18 05:36 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
It’ll run 13.20’s
Re: What will it run? [Re: dannysbee] #2541659
08/26/18 06:25 PM
08/26/18 06:25 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Originally Posted By dannysbee
9.80 if it's sorted
Agree
Re: What will it run? [Re: RRandP92] #2541671
08/26/18 06:47 PM
08/26/18 06:47 PM
Nevada
merpar Offline
merpar  Offline
Nevada
Just guessing from past experience. I'll say 10.20 to 10.10 around 135 mph
Re: What will it run? [Re: RRandP92] #2541684
08/26/18 07:22 PM
08/26/18 07:22 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
9.782 @ 137.5
Re: What will it run? [Re: RRandP92] #2541686
08/26/18 07:25 PM
08/26/18 07:25 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
10.0...
Re: What will it run? [Re: RRandP92] #2541709
08/26/18 08:01 PM
08/26/18 08:01 PM
Cab_Burge Online work
Cab_Burge  Online Work
if the weight is with the driver it should run 9.80 at 137.+ MPH once sorted out with open headers twocents
My old pump gas Duster ran 9.993 at 134.8 MPH corked up(3.0 inch exhaust system to the rear bumper) on pump swill with a 518 C.I. 400 block stroker motor with a little less compression weighing 3450 lbs. with me in it. IHTHs up
Good luck, let us know what it does thumbs
Re: What will it run? [Re: RRandP92] #2541762
08/26/18 10:34 PM
08/26/18 10:34 PM
TN
RRandP92 Offline OP
RRandP92  Offline OP
TN
Weight is with driver. 2in fenderwell headers into 3.5in exhaust straight through mufflers dumped in front of rear tires. Would be great if it went a 10.0 N/A
Re: What will it run? [Re: RRandP92] #2541768
08/26/18 10:44 PM
08/26/18 10:44 PM
Santa Rosa, Calif
angleiron2 Offline
angleiron2  Offline
Santa Rosa, Calif
I have a similar 512 combination. My 69 Dart is 3500 pounds with Driver. Indy EZ heads opened to max wedge size ,Indy intake ,1050 , one of Dwayne’s solid rollers 268/270 duration 646/646 lift,11.2 to1 compression,Ultimate 9 1/2 converter. The car has Caltracs and 410 Ratio with 10.5 x 29.5x 15 radials. Yesterday it ran 9.86 trough the mufflers at 134.I think it would probably do 9.70 uncorked with a little tweaking, but its time to slow it down a bit.
Re: What will it run? [Re: RRandP92] #2541777
08/26/18 11:04 PM
08/26/18 11:04 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Nice going Dave!!😎
Did you get scolded?
As for the OP, should be easy low low 10’s.
9’s in decent air after it’s sorted out.
Re: What will it run? [Re: angleiron2] #2541781
08/26/18 11:13 PM
08/26/18 11:13 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Judgng from your location were you at Famoso? Or Sears Point (Infineon.. whatever they’re calling it these days).
Re: What will it run? [Re: fast68plymouth] #2541793
08/26/18 11:23 PM
08/26/18 11:23 PM
Santa Rosa, Calif
angleiron2 Offline
angleiron2  Offline
Santa Rosa, Calif
Yes I did get scolded. Then i added 100 pounds to the car, I put my passenger seat back in I filled the stock fuel tank all the way up and even put my big heavy battery booster pack in the trunk. I though that and the rising temp would slow it enough, but it still ran a 9.96. They weren’t happy. I need to slow it a couple tenths more before I go back. Thanks Dwayne for all your good work an advice.
Re: What will it run? [Re: RRandP92] #2541796
08/26/18 11:25 PM
08/26/18 11:25 PM
UK
rb446 Offline
rb446  Offline
UK
high 9.80's..should do it easy with good hook/60.....
As a comparison which is not even close, my mates '69 Dart, 3180, 446ci/12.7/eddy 320cfm heads/.590 purple solid/victor int/950 DP/4.56/13x31's/SS springs/5000 stall, trap@6700, 10.1's@132+..599fwhp
Re: What will it run? [Re: RRandP92] #2541799
08/26/18 11:32 PM
08/26/18 11:32 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
10.20-10.50 Getting radial tires to work with that combo is going to be the fun part.
[image][/image]
Re: What will it run? [Re: J_BODY] #2541800
08/26/18 11:33 PM
08/26/18 11:33 PM
Santa Rosa, Calif
angleiron2 Offline
angleiron2  Offline
Santa Rosa, Calif
I was at Sears Point/ Sonoma Raceway. Beautiful day, nice sunny 70 degree day.
Re: What will it run? [Re: RRandP92] #2541891
08/27/18 09:33 AM
08/27/18 09:33 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
Should be a high 9's easy.
