Re: filling firewall holes, welding help
[Re: mcat4321]
#2541401
08/25/18 10:17 PM
08/25/18 10:17 PM
Posts: 2,855 Pattison Texas
CSK
Pattison Texas
get a piece of copper, & hold it on the backside of the hole & weld the hole up, be sure & wear thick gloves CLICK HERE
[Re: mcat4321]
#2541510
08/26/18 11:53 AM
08/26/18 11:53 AM
Posts: 8,240 fredericksburg,va
cudaman1969
fredericksburg,va
Use a headed nail, many sizes made, pull through the hole, hold with vise gripes. Weld, grind off excess, non galvanized roofing nails work best (thin head)
[Re: mcat4321]
#2541549
08/26/18 01:27 PM
08/26/18 01:27 PM
Posts: 667 Los Osos, Ca
CKessel
Los Osos, Ca
For bigger holes, I found out that the left over plug from using Blair RotaBroaches work out slick. Measure what size the hole is then find one of the broaches by measuring the inside of the unit. The plug will have somewhat of a flange on it that makes it easy to hold in place for welding.
Carl Kessel
[Re: mcat4321]
#2541662
08/26/18 06:29 PM
08/26/18 06:29 PM
Posts: 4,848 Memphis
HemiRick
Memphis
To easily weld sheet metal you to use .023 wire w gas and a welder that that is infinitely adjustable rather than fixed steps. Otherwise burning it up is all to easy....the copper backing behind helps too.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
