Re: Mech rocker valve wear pattern
[Re: 68hemiss]
#2540675
08/23/18 11:59 PM
08/23/18 11:59 PM
RapidRobert
am trying to find the correct pushrod length. Straub industries has a good utube vid on this. several sources say it is the gold std on this, that at half cam lift you want the rocker to be 90 deg to the valve tip/retainer THEN (at that point) you measure the pushrod length needed for however much preload you want. EDIT & Scott on the vid uses chebby stud mounted rockers & lowers them to get the 90 deg at half lift. & the chebby rocker choice for this needs to be right (for the correct wipe pattern) & you have yours already but FYI Mike at B3 racing is top notch for this. MORE EDIT I had a Q on the vid & the guy says to then lengthen the pushrod till you have zero clearance & I am wondering if it needs to be lengthened further for a certain amt of preload or shortened a bit for the cold or hot clearance for solids ???
[Re: RapidRobert]
#2540676
08/24/18 12:06 AM
08/24/18 12:06 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Get yourself a adjustable push rod to do the job right.. they are cheap EDIT also Crane rockers seem to have some issues.. you might need to shim the shaft up to get it right or even lower it.. that takes a bit of work.. try another rocker(you might end up sending those Cranes back)
[Re: 68hemiss]
#2540688
08/24/18 12:36 AM
08/24/18 12:36 AM
Posts: 4,457 Washington
madscientist
Washington
Go to b3racingengines.com and read his tech pages.
I'm 99.999% sure you need to correct the geometry. I'm that confident.
Make sure you check with him, take your measurements and buy his correction kit BEFORE you measure for pushrods.
This is a shaft system. Pushrod length only affects geometry in that easing or lowering the adjuster will slightly alter rocker ratio.
The adjuster should be out 9/32 of an inch. Correct the geometry and THEN measure for pushrods.
[Re: 68hemiss]
#2540828
08/24/18 11:55 AM
08/24/18 11:55 AM
Posts: 4,206 New York
polyspheric
New York
Sorry, the issue is more complicated than that. The 50% method simply transfers the error to the pushrod side.
Boffin Emeritus
[Re: polyspheric]
#2540899
08/24/18 02:44 PM
08/24/18 02:44 PM
madscientist
Washington
Sorry, the issue is more complicated than that. The 50% method simply transfers the error to the pushrod side. Exactly. That's why I suggested to the OP to call Mike at B3 and let Mike help him. This stuff about its good enough just isn't. You can fix these things now without machining the stands off an using blocks. It works. It's cost effective. And it should be done with virtually every rocker arm out there.
[Re: madscientist]
#2540973
08/24/18 05:57 PM
08/24/18 05:57 PM
Posts: 2,861 Pattison Texas
CSK
Pattison Texas
Sorry, the issue is more complicated than that. The 50% method simply transfers the error to the pushrod side. Exactly. That's why I suggested to the OP to call Mike at B3 and let Mike help him. This stuff about its good enough just isn't. You can fix these things now without machining the stands off an using blocks. It works. It's cost effective. And it should be done with virtually every rocker arm out there. Absolutely !!! Mike set up my T&D rockers, had to raise them quite abit & move them away from the valves.
[Re: CSK]
#2541005
08/24/18 07:23 PM
08/24/18 07:23 PM
madscientist
Washington
Sorry, the issue is more complicated than that. The 50% method simply transfers the error to the pushrod side. Exactly. That's why I suggested to the OP to call Mike at B3 and let Mike help him. This stuff about its good enough just isn't. You can fix these things now without machining the stands off an using blocks. It works. It's cost effective. And it should be done with virtually every rocker arm out there. Absolutely !!! Mike set up my T&D rockers, had to raise them quite abit & move them away from the valves. That's a bit of correction but think how many guys out there running the same stuff (or even of lesser quality) that have NO correction on their stuff? You can bet their valve train is pissed off to no end. I love Mikes system. Simple, cost effective and it flat works.
[Re: madscientist]
#2541057
08/24/18 10:08 PM
08/24/18 10:08 PM
RapidRobert
& Mike was the one that pointed me to the straub vid for the 50% deal being ideal. It would be way harder to find the right angle with OE type rockers as opposed to the chebby types that you just raise & lower the polylock especially if you have to mill the stands to lower the shafts and he wanted me to call back for further edumacation.
[Re: RapidRobert]
#2541060
08/24/18 10:16 PM
08/24/18 10:16 PM
madscientist
Washington
& Mike was the one that pointed me to the straub vid for the 50% deal being ideal. It would be way harder to find the right angle with OE type rockers as opposed to the chebby types that you just raise & lower the polylock especially if you have to mill the stands to lower the shafts and he wanted me to call back for further edumacation. Did you see the picture csk posted? That's what a correction looks like. You just can't move the shafts up and down. If they go up, they have to move away from the valve. If they go down, they have to move closer to the valve too.
[Re: 68hemiss]
#2541064
08/24/18 10:42 PM
08/24/18 10:42 PM
polyspheric
New York
The diff is that the stand motion is vertical (unless you make new offset stands), while the valve stem height moves at the stem angle (15, 18 etc.).
Boffin Emeritus
[Re: polyspheric]
#2541065
08/24/18 10:45 PM
08/24/18 10:45 PM
CSK
Pattison Texas
The diff is that the stand motion is vertical (unless you make new offset stands), while the valve stem height moves at the stem angle (15, 18 etc.). The shaft holes have been slotted,makes it offset, so it also helps the pushrod side.
[Re: madscientist]
#2541098
08/25/18 12:37 AM
08/25/18 12:37 AM
RapidRobert
Did you see the picture csk posted? That's what a correction looks like. Now I do
[Re: wyrmrider]
#2541129
08/25/18 03:27 AM
08/25/18 03:27 AM
madscientist
Washington
mad that 9/32 distance you quoted was measured how? thanks many adjusters today are much longer from the ball to the thread so the old "3 thread" setup no longer works and results in too short pushrods I like the adjusters up as close to the rocker as possible leaving some room for adjustment
while roller tip rockers do not get the side thrust that iron or stock rockers do they need the fix shown in the pic above
Iron rockers need a fix if off because they can give side thrust
From the bottom of the rocker to the end of the ball. And that's as long as the oil feed hole to the adjuster is drilled right under the part where the adjuster goes through. I had one set of Crane W-2 rockers that had the oil hole about .090 lower than directly under where the adjuster comes through so you has to run the adjuster a bit lower or you'd smoke the adjuster. That was the only set of rockers I've ever seen drilled like that.
[Re: 68hemiss]
#2541194
08/25/18 11:19 AM
08/25/18 11:19 AM
polyspheric
New York
Side thrust (sliding contact between the pallet radius and the stem tip) is present in all non-roller rocker arms BY DESIGN. It's not a mistake, it's needed to produce an oil wedge between the two surfaces.
Boffin Emeritus
