I am putting together a stroker 440 using a mech cam and ductile iron rockers and am trying to find the correct pushrod length. The valve pattern is much wider with the crane rockers than you typically see with roller rockers. Anyone have a pic of how the pattern should look with these type rockers? Thanks
