Re: Wilwood Pull Type Clutch Slave Cylinder
[Re: earlymopar]
#2538670
08/19/18 08:43 PM
08/19/18 08:43 PM
Posts: 25,960 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I used one on my SB TKO 600 conversion with the 10 7/8" lever and a 3/4" MC. Works OK. As you probably know, there are different length levers so some might not work with my combo.
[Re: earlymopar]
#2539056
08/20/18 02:51 PM
08/20/18 02:51 PM
John_Kunkel
Rio Linda, CA
The fork dimension is the overall length.
The clutch is a 10 1/2" diaphragm with the release bearing supplied by American Powertrain (which I believe is a modified Hemi 833). No return spring on the pedal, I used the factory-style fork return spring and set the fork free play at the factory 5/32".
[Re: earlymopar]
#2539577
08/21/18 02:04 PM
08/21/18 02:04 PM
John_Kunkel
Rio Linda, CA
The 5/32" is measured at the pull rod nut.
