What are these Mopar Heads #2539224
08/20/18 07:57 PM
08/20/18 07:57 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
Can anyone tell me what heads these are?
Re: What are these Mopar Heads [Re: Dodgem] #2539227
08/20/18 08:01 PM
08/20/18 08:01 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
nothing shows up?
Can you attach them to the email?
Old Geezer Racing
Re: What are these Mopar Heads [Re: Dodgem] #2539230
08/20/18 08:03 PM
08/20/18 08:03 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
Yes!
new to google pictures i click links they work used to use anoth picher hosting but not now?
Re: What are these Mopar Heads [Re: Dodgem] #2539231
08/20/18 08:05 PM
08/20/18 08:05 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Try postimage….Just google them pretty easy and free smile
Re: What are these Mopar Heads [Re: Dodgem] #2539238
08/20/18 08:14 PM
08/20/18 08:14 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
Ran that number, stage 6
Re: What are these Mopar Heads [Re: Dodgem] #2539240
08/20/18 08:16 PM
08/20/18 08:16 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
Thanks what version and valves. do they need that intake spacer?
Re: What are these Mopar Heads [Re: Dodgem] #2539245
08/20/18 08:30 PM
08/20/18 08:30 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
Ok more pictures this guy does not know what he has got wants to start building a mopar/
Re: What are these Mopar Heads [Re: Dodgem] #2539326
08/20/18 11:19 PM
08/20/18 11:19 PM
AndyF Offline
AndyF  Offline
Looks like Stage VI stuff to me. Are those home made gaskets or some sort of spacers sitting in the valley. Look like they were cut out with a torch or something.
That looks like a wide intake so maybe a Stage VI intake for an RB block? I'm not sure on those rockers. Might be Harland Sharp with a bad color balance on the camera? If they are red then I don't know what brand that is, maybe someone else does.
Stage VI stuff is really iffy in terms of quality. Some of it was okay and some of it wasn't. If you are going to use those parts they need to be double checked by someone who is familiar with all of the problems that Mopar had with those heads.
Re: What are these Mopar Heads [Re: Dodgem] #2539327
08/20/18 11:22 PM
08/20/18 11:22 PM
crabman173
crabman173
Sell them on Ebay and save yourself a Load of trouble
Re: What are these Mopar Heads [Re: AndyF] #2539352
08/20/18 11:52 PM
08/20/18 11:52 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
thanks his dad was an old school make it yourself type. he also found a set of P4120352 / 3614476 heads with 2.14/1.81's of his fathers so far.
Says he has a windowed hemi block but thinks there might be a couple good ones in the stash. does not know what most stuff is.
Re: What are these Mopar Heads [Re: Dodgem] #2539413
08/21/18 02:45 AM
08/21/18 02:45 AM
AndyF Offline
AndyF  Offline
Tell him to drag it all out and take good photos. Post the photos on here in the WIW section and people will tell him what the parts are and what they might be worth. Lots of guys on here can identify parts from a good picture.
Re: What are these Mopar Heads [Re: Dodgem] #2539419
08/21/18 03:33 AM
08/21/18 03:33 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Stage VI heads.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: What are these Mopar Heads [Re: Dodgem] #2539470
08/21/18 10:41 AM
08/21/18 10:41 AM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Stage 6
Re: What are these Mopar Heads [Re: Dodgem] #2539477
08/21/18 10:52 AM
08/21/18 10:52 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
That is indeed an obsolete stage vi rb intake. I had the same one on the Mirada mill, only the 4500 flange. When they made those you no longer had to run the spacers required for any RB intake. It was amazing how that intake and a dominator woke up my fairly mild build.
Re: What are these Mopar Heads [Re: Dodgem] #2539489
08/21/18 11:17 AM
08/21/18 11:17 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
They were a really good idea back in the early 90’s..... just poorly executed. There’s some ancient reading on these in the archives here....
Dwayne Porter was/is the “go to” guy on these heads.... but he’ll be the first to tell you that if your looking to buy, get something else.
While I really didn’t have any big probs with my stage vl heads they had the usual probs of valve heights all over the board and why the didn’t use a longer valve is beyond me.
Raised exhaust ports can make header installs a treat. Luckily in my case we were able to lower the engine slightly and the J didn’t have the longitudeinal torsion bars to fight with. Still had to reconstruct a couple tubes though.
Re: What are these Mopar Heads [Re: Dodgem] #2539495
08/21/18 11:31 AM
08/21/18 11:31 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
There’s actually pics of two different heads there....... stage IV and stage VI.
The 3614476 is an old stage IV head.
The rockers on the stage VI look like the Mancini rockers to me...... but could just as easily be Pro Comps.
If they have no bearings in them, then probably Mancini.
If they have needle bearings, then Pro Comps(or some other variation of Shang Hai Sharps).
Hard to tell by just looking at a pic, but the port openings on the stage VI look bigger that std, but not fully MW size either....... might be the reason for the home made gaskets.
A quick measurement would answer that question.
That 6835 stamped into the stage VI head is likely a “job number” from some shop, which means it’s likely someone went through them at one point.
Re: What are these Mopar Heads [Re: J_BODY] #2539620
08/21/18 03:17 PM
08/21/18 03:17 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
Cool.
Re: What are these Mopar Heads [Re: fast68plymouth] #2539623
08/21/18 03:23 PM
08/21/18 03:23 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
Yes he sent pictures of the stage six first and then the iron stage 4 he is digging through his dads stuff to see what he has and wants to start slow building a drag car. He is young and is overwhelmed on where to start on his dads parts stash. said he remembers his dad was a big Mancini customer (weren't we all) he has a lot of digging and learning to do.
