Re: What are these Mopar Heads
[Re: Dodgem]
#2539227
08/20/18 08:01 PM
08/20/18 08:01 PM
Posts: 1,505 TN
SCATPACK 1
TN
nothing shows up? Can you attach them to the email?
Old Geezer Racing
[Re: Dodgem]
#2539327
08/20/18 11:22 PM
08/20/18 11:22 PM
crabman173
crabman173
Sell them on Ebay and save yourself a Load of trouble
[Re: AndyF]
#2539352
08/20/18 11:52 PM
08/20/18 11:52 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
thanks his dad was an old school make it yourself type. he also found a set of P4120352 / 3614476 heads with 2.14/1.81's of his fathers so far.
Says he has a windowed hemi block but thinks there might be a couple good ones in the stash. does not know what most stuff is.
[Re: Dodgem]
#2539495
08/21/18 11:31 AM
08/21/18 11:31 AM
Posts: 14,493 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
There’s actually pics of two different heads there....... stage IV and stage VI.
The 3614476 is an old stage IV head.
The rockers on the stage VI look like the Mancini rockers to me...... but could just as easily be Pro Comps. If they have no bearings in them, then probably Mancini. If they have needle bearings, then Pro Comps(or some other variation of Shang Hai Sharps).
Hard to tell by just looking at a pic, but the port openings on the stage VI look bigger that std, but not fully MW size either....... might be the reason for the home made gaskets. A quick measurement would answer that question.
That 6835 stamped into the stage VI head is likely a “job number” from some shop, which means it’s likely someone went through them at one point.
[Re: fast68plymouth]
#2539623
08/21/18 03:23 PM
08/21/18 03:23 PM
Dodgem
Ontario, Canada
That 6835 stamped into the stage VI head is likely a “job number” from some shop, which means it’s likely someone went through them at one point. Yes he sent pictures of the stage six first and then the iron stage 4 he is digging through his dads stuff to see what he has and wants to start slow building a drag car. He is young and is overwhelmed on where to start on his dads parts stash. said he remembers his dad was a big Mancini customer (weren't we all) he has a lot of digging and learning to do.
