Can H beam rods be rebuilt?
#2538699
08/19/18 09:43 PM
08/19/18 09:43 PM
Posts: 304 Portland, Oregon
Digger73
Portland, Oregon
I have a set of H beam rods that have been exposed to heat due to bearing issues. The bearings didn't spin but they were ruined because of tight clearance. So I am trying to find out if the rods can be rebuilt? Also, could they be trusted in a very healthy 500" stroker?
Thanks, Digger73 (Mike)
I live with fear everyday but, sometimes she lets me race!
Re: Can H beam rods be rebuilt?
[Re: Digger73]
#2538706
08/19/18 09:52 PM
08/19/18 09:52 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
If the rod discolored, I would replace it. If it is a cracked cap design, maybe not. Don't know if they can be machined flat and rehoned. As far as durability in your stroker, you get what you pay for.
[image][/image]
[Re: sgcuda]
#2538711
08/19/18 09:59 PM
08/19/18 09:59 PM
Posts: 10,706 North Dakota
6PakBee
North Dakota
If the rod discolored, I would replace it. If it is a cracked cap design, maybe not. Don't know if they can be machined flat and rehoned. As far as durability in your stroker, you get what you pay for. If you didn't spin the bearings I'd be tempted to reuse them. If you have no discoloration that's good but I'm not sure discoloration would be a problem. I've had many B/RB rods assembled by using a rod furnace to expand the small end of the rod on a pressed pin assembly. As to cracked cap rods, I thought the only way you could rebuild them was to bore them oversize and use the oversize bearings. As to durability in a stroker, I agree with sgcuda.
[Re: Digger73]
#2538839
08/20/18 03:54 AM
08/20/18 03:54 AM
Posts: 43,127 Bend,OR USA
Cab_Burge
What brand are these rods? Metal is metal, correct? My message is the rods are machined from unfinished to finished so they been size once incorrectly so why not have them magnaflux to see if they are cracked or not If they magged okay have the bolts replaced and them resize the big end and use them
[Re: 6PakBee]
#2538876
08/20/18 08:51 AM
08/20/18 08:51 AM
sgcuda
If the rod discolored, I would replace it. If it is a cracked cap design, maybe not. Don't know if they can be machined flat and rehoned. As far as durability in your stroker, you get what you pay for. If you didn't spin the bearings I'd be tempted to reuse them. If you have no discoloration that's good but I'm not sure discoloration would be a problem. I've had many B/RB rods assembled by using a rod furnace to expand the small end of the rod on a pressed pin assembly. As to cracked cap rods, I thought the only way you could rebuild them was to bore them oversize and use the oversize bearings. As to durability in a stroker, I agree with sgcuda. I wasn't referring to the small end. If the large end is discolored from heat, I would toss it.
[Re: sgcuda]
#2538989
08/20/18 01:10 PM
08/20/18 01:10 PM
6PakBee
North Dakota
If the rod discolored, I would replace it. If it is a cracked cap design, maybe not. Don't know if they can be machined flat and rehoned. As far as durability in your stroker, you get what you pay for. If you didn't spin the bearings I'd be tempted to reuse them. If you have no discoloration that's good but I'm not sure discoloration would be a problem. I've had many B/RB rods assembled by using a rod furnace to expand the small end of the rod on a pressed pin assembly. As to cracked cap rods, I thought the only way you could rebuild them was to bore them oversize and use the oversize bearings. As to durability in a stroker, I agree with sgcuda. I wasn't referring to the small end. If the large end is discolored from heat, I would toss it. I realize that. I was just pointing out that IMHO discoloration is not an automatic reason for rejection.
[Re: 6PakBee]
#2539010
08/20/18 01:32 PM
08/20/18 01:32 PM
Posts: 4,712 Moved to N.E. Tennessee
GomangoCuda
If they got hot enough to change color then the heat treat is altered. If you have the hardness tested the areas that changed color will be different than the rest of the rod.
[Re: GomangoCuda]
#2539023
08/20/18 01:55 PM
08/20/18 01:55 PM
Posts: 20,163 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Is it worth less than 100.00 a piece to chance it.
[Re: pittsburghracer]
#2539091
08/20/18 03:34 PM
08/20/18 03:34 PM
Posts: 14,493 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Is it worth less than 100.00 a piece to chance it. Hard to argue with that for a new high hp build. If they got hot enough to turn color, it’s likely they’ll need resizing(not free), which makes that under $100/ea money a little more palatable.
[Re: Digger73]
#2539093
08/20/18 03:39 PM
08/20/18 03:39 PM
Posts: 4,206 New York
polyspheric
New York
A color change probably exceeded the anneal temperature, which means the hardness/ductility is affected. I'd change them.
Boffin Emeritus
[Re: Digger73]
#2539123
08/20/18 04:31 PM
08/20/18 04:31 PM
Digger73
Portland, Oregon
What you all have said has confirmed what I was thinking. My first inclination was to toss them and start over. The only reason I was even considering a redo of the big end was to preserve the balance job on the rotational assembly. I have other options that I may pursue also. Just trying to gather all the information I can to make the most economical and educated choice. The whole once bitten twice shy thing. Thanks for all the input.
Digger73 (Mike)
[Re: Digger73]
#2539152
08/20/18 05:30 PM
08/20/18 05:30 PM
Digger73
Portland, Oregon
The truth of the matter is that I am sort of embarrassed. Due to the fact that I work for a living and have very little extra disposable money flow, I use 440 Source kits. I know I will get all kinds of back lash but it is what I can afford and it allows me to continue to race. I could call them but I am not too sure the rods are even worth any more effort. I take full responsibility for the failure as I was trying something new and am now paying the price for it. I had the rod and main bearings coated with an anti-friction coating. When I assembled the engine the mains were very good on the clearance but the rods were on the tight side. I wanted to assemble the engine and get it in the car so against my better judgement I didn't replace the rod bearings. So I am to fault...
Digger73 (Mike)
[Re: Digger73]
#2539186
08/20/18 06:19 PM
08/20/18 06:19 PM
Posts: 20,163 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Nothing to be ashamed about when Racing on a budget. Thanks to 440source many years ago when they opened up I was finally able to build my first Stroker engine. That engine went 8.60’s@155mph in my Daytona and that engine rotating assembly is still going strong in a street car today.
[Re: wyrmrider]
#2539796
08/21/18 10:40 PM
08/21/18 10:40 PM
dartman366
Mt. Vernon, Ohio
No way did they get close to anneal temp if the bearings did not spin you not all the post heat temp processes they go through are they still round torque the bolts down a couple of times with the same lube- do they change dimensions? mag is not going to show you anything if a little out of round- which happens to even non hated rods after a few runs cut the caps flat and re hone do not worry about the dimension a the parting line it can be a little wide who makes - actually makes- these rods no colour pics? I tend to agree with this to a point but since there is no pic's then this is my opinion,, if there is some minor coloring then they may/probably will be ok to re-use after reconditioning, if they are black then pitch them in the nearest scrap hopper and call the supplier of you choosing.
