Ball joint pitman arm #2538668
08/19/18 08:38 PM
08/19/18 08:38 PM
BeavisHQV Offline OP
can this
https://youtu.be/YbSDHARELyw
Cause that
https://youtu.be/qBPb15xdV3Q
And what happened to that ball joint?
Box is a ff stage III
Re: Ball joint pitman arm [Re: BeavisHQV] #2538673
08/19/18 08:49 PM
08/19/18 08:49 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
What do you think?
You think any slop in the steering linkage will result in play at the wheel?
What happened?
You tell us. Is it 150k miles old and wore out or new out of the box and defective?
Don't be the exception.
Re: Ball joint pitman arm [Re: BeavisHQV] #2538693
08/19/18 09:27 PM
08/19/18 09:27 PM
Pitman arm looked decent when i changed the steering box aprox 300 miles before.
Re: Ball joint pitman arm [Re: BeavisHQV] #2538708
08/19/18 09:56 PM
08/19/18 09:56 PM
North Dakota
6PakBee Online content
6PakBee  Online Content
North Dakota
Hmm. How did you remove the tie rod end of the pitman arm when you changed the steering box?
Re: Ball joint pitman arm [Re: BeavisHQV] #2538743
08/19/18 11:01 PM
08/19/18 11:01 PM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
I would say that the ball joint on that pitman arm is trashed. I would expect to see a lot of backlash in the steering wheel. Why did it go out? Probably related to how it was handled during the steering box replacement.
Re: Ball joint pitman arm [Re: BeavisHQV] #2539129
08/20/18 04:46 PM
08/20/18 04:46 PM
changed the box with a firm feel unit. worked on all parts with a pulley.
