Distributor choices #2538457
08/19/18 09:30 AM
08/19/18 09:30 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
I am helping a friend with a hemi build. It’s an alum Indy max with stage v heads. It’s got a fuel injection system on it so we need a distributor that we can lock the timing. I’ve had good results with the PerTronix unit in my stock distributors because it avoids an external ignition box. Anybody have any suggestions on a distributor?
Re: Distributor choices [Re: fastmark] #2538479
08/19/18 11:34 AM
08/19/18 11:34 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I've used locked out stock distributors, 440Source, and MSD. You're not concerned with advance, so I don't think it will be a critical choice. I do feel that a better choice would be a crank trigger, for timing accuracy, though.
[image][/image]
Re: Distributor choices [Re: fastmark] #2538489
08/19/18 11:54 AM
08/19/18 11:54 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
This car is all show and will never see a track. Crank trigger is not needed. I wonder if the Pertronix unit will fit the 440 source distributor?
Re: Distributor choices [Re: fastmark] #2538547
08/19/18 02:13 PM
08/19/18 02:13 PM
AndyF Offline
AndyF  Offline
What type of fuel injection system is on it? You might take a look at the Holley Hyperspark distributor. Those distributors are designed for EFI and they are locked. No curve, no vacuum advance, just a pickup. Very simple and not too expensive.
Re: Distributor choices [Re: fastmark] #2538568
08/19/18 02:49 PM
08/19/18 02:49 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
It’s got a electronic converted Hillborn system. Not my choice for sure.
Re: Distributor choices [Re: fastmark] #2538622
08/19/18 06:47 PM
08/19/18 06:47 PM
AndyF Offline
AndyF  Offline
What kind of signal does it need? The Hyperspark is a Hall effect pickup which is what most EFI systems like.
I assume the EFI system needs a crank signal from the distributor and then the EFI system controls the timing or is something else going on?
