Edelbrock head repair #2537968
08/18/18 01:22 AM
08/18/18 01:22 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
I wanted to confirm this before I go further--heres the deal.
I need to put Helicoil inserts into my RPM heads. 2 per head , the #2 / #4 holes / rocker shaft stands --the long studs/bolts .
since the threads are pretty far down in the rocker stand...want to be sure on how deep to drill .
so the Helicoil is about .50 deep. Do i need to simply drill the factory hole .50 deep and thats it? Or does the insert need to go deeper in these particular stand holes ??
Checking before I drill !
Im using studs not bolts on these 4 holes
Re: Edelbrock head repair [Re: 493_DART] #2537995
08/18/18 02:49 AM
08/18/18 02:49 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
You can heli-coil the 1/3/5, but the 2/4 wont have enough material because those holes are in the common divider walls of the intake ports.
Re: Edelbrock head repair [Re: BradH] #2538146
08/18/18 02:46 PM
08/18/18 02:46 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
well....the threads are ripping out...so... ??
Re: Edelbrock head repair [Re: 493_DART] #2538157
08/18/18 03:23 PM
08/18/18 03:23 PM
BradH Offline
BradH  Offline
Maybe someone who does this stuff for a living can suggest a repair.
Were you using studs or bolts in those positions? And what sort of spring loads were your rockers shaft assemblies subjected to?
Re: Edelbrock head repair [Re: BradH] #2538195
08/18/18 06:18 PM
08/18/18 06:18 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
Studs...400lb open
Re: Edelbrock head repair [Re: 493_DART] #2538446
08/19/18 08:08 AM
08/19/18 08:08 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Bob at MCH repaired one of my heads after the engine let go, did a real nice job.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Edelbrock head repair [Re: 493_DART] #2538536
08/19/18 01:34 PM
08/19/18 01:34 PM
try calling Edlebrock and ask them about this twocents scope
Re: Edelbrock head repair [Re: 493_DART] #2538555
08/19/18 02:20 PM
08/19/18 02:20 PM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
Heli coils are pretty simple, you must have enough material to drill the hole oversized to tap it for the coil and you need to measure the depth of the hole. The best would be to be able to be deep enough to use the entire coil but Have cut the coil down in the past to shorten it for a hole that is not deep enough. also the hole MUST be drilled strait and taped strait. If any of this seems too much for you have a professional do it.
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: Edelbrock head repair [Re: 493_DART] #2538575
08/19/18 03:37 PM
08/19/18 03:37 PM
New York, USA
Chargerfan68 Offline
New York, USA
They also have longer than the standard 1/2” long helicoils in some sizes. I did buy a box of 3/4” long helicoils in 3/8” size from one of the big suppliers of fasteners and hardware on the net. If it is possible to repair, i would try to use the longest that is possible. I think the company i used was Mcmaster Carr or MSC industrial. Good luck
Re: Edelbrock head repair [Re: 493_DART] #2538662
08/19/18 08:19 PM
08/19/18 08:19 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
If the heads are heavily ported, there’s a possibility you’ll break through into the ports when you drill over size for the heli-coil.
