Re: Edelbrock head repair
[Re: 493_DART]
#2538446
08/19/18 08:08 AM
08/19/18 08:08 AM
Posts: 3,210 robin hood country
deaks
robin hood country
Bob at MCH repaired one of my heads after the engine let go, did a real nice job. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: 493_DART]
#2538555
08/19/18 02:20 PM
08/19/18 02:20 PM
Posts: 1,406 New Jersey, USA
yella71
New Jersey, USA
Heli coils are pretty simple, you must have enough material to drill the hole oversized to tap it for the coil and you need to measure the depth of the hole. The best would be to be able to be deep enough to use the entire coil but Have cut the coil down in the past to shorten it for a hole that is not deep enough. also the hole MUST be drilled strait and taped strait. If any of this seems too much for you have a professional do it.
71 challenger convertable, 64 sport fury 383 ci with factory air
99 sebring convertable
89 CTD pup
[Re: 493_DART]
#2538575
08/19/18 03:37 PM
08/19/18 03:37 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
They also have longer than the standard 1/2” long helicoils in some sizes. I did buy a box of 3/4” long helicoils in 3/8” size from one of the big suppliers of fasteners and hardware on the net. If it is possible to repair, i would try to use the longest that is possible. I think the company i used was Mcmaster Carr or MSC industrial. Good luck
[Re: 493_DART]
#2538662
08/19/18 08:19 PM
08/19/18 08:19 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
If the heads are heavily ported, there’s a possibility you’ll break through into the ports when you drill over size for the heli-coil.
