Woodgrain Adhesive for Non Rally Dash #253802
03/14/09 09:16 PM
03/14/09 09:16 PM
Manhattan, IL
SixPackRT Offline OP
Manhattan, IL
Does anyone carry the correct woodgrain adhesive for a 70 Coronet RT w/non rally dash. I know the original adhesive is pretty unique and I believe 70 was a different shade. I am in the process of assembling my dash and I located the cleanest original pieces I could find, but they are not perfect. Am I stuck with clean originals or does someone have the correct adhesive inserts. These are not the same as the rally dash pieces that are currently available. Thanks, Scott
70 Coronet RT 440+6
64 Dodge 330 - Future Hemi Clone
17 Challenger Hellcat - Green Go Driver
86 Buick T-Type Turbo V-6
Re: Woodgrain Adhesive for Non Rally Dash [Re: SixPackRT] #253803
03/15/09 01:15 AM
03/15/09 01:15 AM
California
70SportSatellite Offline
super street
super street
California
Hi,
The 1970 Coronet R/T standard dash and Sport Satellite share the same woodgrain pieces if I'm not mistaken. The difference being the emblem above the glove box. I'm guessing you have door trim that has it also, as does mine.
I was able to find some stuff made by REM that although not exact, it's as close as I was able to find and I actually like it. Here are a couple of pictures.
Re: Woodgrain Adhesive for Non Rally Dash [Re: 70SportSatellite] #253804
03/15/09 01:16 AM
03/15/09 01:16 AM
California
super street
super street
California
door trim
Re: Woodgrain Adhesive for Non Rally Dash [Re: 70SportSatellite] #253805
03/15/09 01:22 AM
03/15/09 01:22 AM
California
super street
super street
California
another
Re: Woodgrain Adhesive for Non Rally Dash [Re: 70SportSatellite] #253806
03/15/09 12:42 PM
03/15/09 12:42 PM
Manhattan, IL
Manhattan, IL
Yes, the dash pieces would be the same. The piece over the glove box has an RT emblem on it but it is put on and melted in from behind. My door pieces are fine, I found really nice originals. Does the adhesive you found have the grain pattern on the surface like the original? The color looks real close. do you have any close ups you can email me? Thanks for the help. Any others with ideas or that have used any product out there. Thanks, Scott
70 Coronet RT 440+6
Re: Woodgrain Adhesive for Non Rally Dash [Re: SixPackRT] #253807
03/15/09 07:24 PM
03/15/09 07:24 PM
California
super street
super street
California
Sorry, I don't have any close ups. It does have the grain.
Re: Woodgrain Adhesive for Non Rally Dash [Re: SixPackRT] #253808
03/15/09 08:00 PM
03/15/09 08:00 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
another
here is a factory piece...
Re: Woodgrain Adhesive for Non Rally Dash [Re: 340dart4spd ] #253809
03/15/09 08:03 PM
03/15/09 08:03 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
another
Re: Woodgrain Adhesive for Non Rally Dash [Re: 340dart4spd ] #253810
03/15/09 08:08 PM
03/15/09 08:08 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
one more
Re: Woodgrain Adhesive for Non Rally Dash [Re: 70SportSatellite] #253811
03/15/09 10:39 PM
03/15/09 10:39 PM
Manhattan, IL
Manhattan, IL
Did you order direct from REM or from one of their distributors? and how did it come? Thanks, Scott
70 Coronet RT 440+6
Re: Woodgrain Adhesive for Non Rally Dash [Re: SixPackRT] #253812
03/15/09 10:50 PM
03/15/09 10:50 PM
California
super street
super street
California
It's been a while but I think I got it through Totally Auto. Word of caution! Make sure they send it in a tube! The first time it came in a flimsy box than was bent and left some nasty creases, and yep, even after requesting a tube the second time they sent in a different package that was still damaged! Thank you MR. UPS! Anyway, the third time it did come in a tube and all was well. Good Luck.
Re: Woodgrain Adhesive for Non Rally Dash [Re: 70SportSatellite] #253813
03/15/09 10:54 PM
03/15/09 10:54 PM
Manhattan, IL
Manhattan, IL
Thanks I'll give it a try I have extra pieces so I can do one and compare.
Thanks again, Scott
70 Coronet RT 440+6
Re: Woodgrain Adhesive for Non Rally Dash [Re: SixPackRT] #253814
03/16/09 09:51 AM
03/16/09 09:51 AM
California
super street
super street
California
If you're unsure I can send you a small sample from some leftover material to look at before buying it. let me know.
