Woodgrain Adhesive for Non Rally Dash
#253802
03/14/09 09:16 PM
03/14/09 09:16 PM
Posts: 408 Manhattan, IL
SixPackRT
Manhattan, IL
Does anyone carry the correct woodgrain adhesive for a 70 Coronet RT w/non rally dash. I know the original adhesive is pretty unique and I believe 70 was a different shade. I am in the process of assembling my dash and I located the cleanest original pieces I could find, but they are not perfect. Am I stuck with clean originals or does someone have the correct adhesive inserts. These are not the same as the rally dash pieces that are currently available. Thanks, Scott
70 Coronet RT 440+6 64 Dodge 330 - Future Hemi Clone 17 Challenger Hellcat - Green Go Driver 86 Buick T-Type Turbo V-6
Re: Woodgrain Adhesive for Non Rally Dash
[Re: 70SportSatellite]
#253806
03/15/09 12:42 PM
03/15/09 12:42 PM
SixPackRT
Manhattan, IL
Yes, the dash pieces would be the same. The piece over the glove box has an RT emblem on it but it is put on and melted in from behind. My door pieces are fine, I found really nice originals. Does the adhesive you found have the grain pattern on the surface like the original? The color looks real close. do you have any close ups you can email me? Thanks for the help. Any others with ideas or that have used any product out there. Thanks, Scott
[Re: 340dart4spd ]
#253809
03/15/09 08:03 PM
03/15/09 08:03 PM
340dart4spd
Parts Problem
Parts Problem
[Re: 340dart4spd ]
#253810
03/15/09 08:08 PM
03/15/09 08:08 PM
340dart4spd
Parts Problem
Parts Problem
#253811
03/15/09 10:39 PM
03/15/09 10:39 PM
SixPackRT
Manhattan, IL
Did you order direct from REM or from one of their distributors? and how did it come? Thanks, Scott
#253813
03/15/09 10:54 PM
03/15/09 10:54 PM
SixPackRT
Manhattan, IL
Thanks I'll give it a try I have extra pieces so I can do one and compare. Thanks again, Scott
