HP Performance engine blocks #2536243
08/14/18 04:19 PM
08/14/18 04:19 PM
Charlotte, North Carolina
sgcuda Offline OP
sgcuda  Offline OP
Are their engine blocks any good? Their website advertises hemi and wedge blocks from $3,695. Cast iron and aluminum. But the site seems to be dated, along with their FB page.
Re: HP Performance engine blocks [Re: sgcuda] #2536285
08/14/18 05:36 PM
08/14/18 05:36 PM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
Don't think that they ever got production problems worked out
Few of their aluminum blocks out there but not cast iron
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
Re: HP Performance engine blocks [Re: sgcuda] #2536287
08/14/18 05:40 PM
08/14/18 05:40 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Take my word for it, run as fast as you can away from him. Lier and crook.
Re: HP Performance engine blocks [Re: sgcuda] #2536485
08/14/18 11:24 PM
08/14/18 11:24 PM
sgcuda Offline OP
sgcuda  Offline OP
Well, I have my eye on a block. I wouldn't be dealing with the owner. Just want to know bout the quality of the block.
[image][/image]
Re: HP Performance engine blocks [Re: sgcuda] #2536631
08/15/18 10:41 AM
08/15/18 10:41 AM
an8sec70cuda Offline
I know you're buying a block second hand, so this really doesn't apply, but I talked w/ them over a year ago (maybe 2 years ago, can't remember) and he assured me they would have blocks rolling in from the foundry in 3 months. You see how true that was. I was warned by others not to deal w/ them.
Never heard much about the block itself to know what issues they have.
I'd call Tim at FHO or any of the other big builders to see what they say. Seems like I remember FHO using some of these blocks when they were actually available. I believe Aruzza used some too, but he went nuts and closed up shop.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: HP Performance engine blocks [Re: an8sec70cuda] #2536654
08/15/18 11:12 AM
08/15/18 11:12 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I talked to Tim at FHO and he said he about went broke warranting them. I have one of those motors, and every thing and I mean everything had to be redone. You don't want to know what 8 new liners cost. Even Ray Barton said they were junk.
Re: HP Performance engine blocks [Re: sgcuda] #2536689
08/15/18 12:16 PM
08/15/18 12:16 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Any aftermarket block is one of only 2 conditions:
1. known to be without flaws, many times by experts
2. pass it by regardless of price
Boffin Emeritus
Re: HP Performance engine blocks [Re: polyspheric] #2536775
08/15/18 03:02 PM
08/15/18 03:02 PM
dogdays Offline
dogdays  Offline
They looked so promising! But that just meant their Webpage designer had it together.
This is so ridiculous! Pontiac freaks can buy iron OR aluminum blocks from two suppliers - All Pontiac or Kauffmann, $3250 for iron, $4600 for aluminum.
R.
Re: HP Performance engine blocks [Re: dogdays] #2536963
08/16/18 12:12 AM
08/16/18 12:12 AM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
R.
A couple friends of mine run the very affordable and readily available iron aftermarket Pontiac blocks into the bottom 8s in 3000+lb cars with nitrous, without issue.
Sickening.....isn't it???
Re: HP Performance engine blocks [Re: sgcuda] #2537041
08/16/18 08:01 AM
08/16/18 08:01 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Yes.
Re: HP Performance engine blocks [Re: jim sciortino] #2537058
08/16/18 09:29 AM
08/16/18 09:29 AM
In The Hills
jughed Offline
jughed  Offline
In The Hills
And sad too. I bought a Mega Block shortblock 11 years ago, put it in the Dart, and have street driven it since. If something ever breaks and the block is turned into scrap iron, what next? There are no iron blocks out there to replace it with. I'm almost tempted to sell it now and go 3rd Gen Hemi.
End those annoying Infolink ads with AdBlockPlus
https://adblockplus.org/
Re: HP Performance engine blocks [Re: sgcuda] #2537107
08/16/18 12:10 PM
08/16/18 12:10 PM
New York
polyspheric Offline
polyspheric  Offline
New York
There has been a brilliant new product for my DD for nearly a decade: a billet DOHC 4 valve cylinder head with revised stem angle, port contour, etc.
The ad is illustrated solely with a CAD/CAM drawing and a mock-up OF ONE CYLINDER - no photograph of the actual product, let alone a test using an ENGINE!
I ordered 3 of them, because I believe what I see on my monitor.
Boffin Emeritus
Re: HP Performance engine blocks [Re: sgcuda] #2537153
08/16/18 01:43 PM
08/16/18 01:43 PM
Zumbrota,MN
als499 Offline
als499  Offline
Zumbrota,MN
Summit sells new 6 bolt main iron LS blocks for $349. it's all about sales volume. If they knew they could sell 1000's and not 10's the price would come way down.
Re: HP Performance engine blocks [Re: sgcuda] #2537289
08/16/18 05:41 PM
08/16/18 05:41 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Low volume = high price.
A billet aluminum block to replace my (excellent, safe to at least 1,500 HP) cast iron OEM, no larger bore available, no specific weight saving claimed, is $9,000.
Boffin Emeritus
