Re: HP Performance engine blocks
[Re: sgcuda]
#2536285
08/14/18 05:36 PM
08/14/18 05:36 PM
Posts: 15,547 Norwich CT USA
moparts
Norwich CT USA
Don't think that they ever got production problems worked out
Few of their aluminum blocks out there but not cast iron
Tom ,
2011 Ram 3500 C&C Diesel 2009 Challenger R/T 1971 Challenger Conv. 511/4 speed 1970 Challenger R/T 503/727
[Re: sgcuda]
#2536631
08/15/18 10:41 AM
08/15/18 10:41 AM
Posts: 13,350 Marion, South Carolina [><]
an8sec70cuda
I know you're buying a block second hand, so this really doesn't apply, but I talked w/ them over a year ago (maybe 2 years ago, can't remember) and he assured me they would have blocks rolling in from the foundry in 3 months. You see how true that was. I was warned by others not to deal w/ them. Never heard much about the block itself to know what issues they have.
I'd call Tim at FHO or any of the other big builders to see what they say. Seems like I remember FHO using some of these blocks when they were actually available. I believe Aruzza used some too, but he went nuts and closed up shop.
[Re: sgcuda]
#2536689
08/15/18 12:16 PM
08/15/18 12:16 PM
Posts: 4,205 New York
polyspheric
New York
Any aftermarket block is one of only 2 conditions: 1. known to be without flaws, many times by experts 2. pass it by regardless of price
Boffin Emeritus
[Re: dogdays]
#2536963
08/16/18 12:12 AM
08/16/18 12:12 AM
Posts: 2,026 Trumbull,CT.
jim sciortino
Trumbull,CT.
They looked so promising! But that just meant their Webpage designer had it together.
This is so ridiculous! Pontiac freaks can buy iron OR aluminum blocks from two suppliers - All Pontiac or Kauffmann, $3250 for iron, $4600 for aluminum.
R. A couple friends of mine run the very affordable and readily available iron aftermarket Pontiac blocks into the bottom 8s in 3000+lb cars with nitrous, without issue. Sickening.....isn't it???
[Re: jim sciortino]
#2537058
08/16/18 09:29 AM
08/16/18 09:29 AM
Posts: 1,229 In The Hills
jughed
In The Hills
And sad too. I bought a Mega Block shortblock 11 years ago, put it in the Dart, and have street driven it since. If something ever breaks and the block is turned into scrap iron, what next? There are no iron blocks out there to replace it with. I'm almost tempted to sell it now and go 3rd Gen Hemi.
[Re: sgcuda]
#2537107
08/16/18 12:10 PM
08/16/18 12:10 PM
polyspheric
New York
There has been a brilliant new product for my DD for nearly a decade: a billet DOHC 4 valve cylinder head with revised stem angle, port contour, etc. The ad is illustrated solely with a CAD/CAM drawing and a mock-up OF ONE CYLINDER - no photograph of the actual product, let alone a test using an ENGINE! I ordered 3 of them, because I believe what I see on my monitor.
Boffin Emeritus
[Re: sgcuda]
#2537153
08/16/18 01:43 PM
08/16/18 01:43 PM
Posts: 750 Zumbrota,MN
als499
Zumbrota,MN
Summit sells new 6 bolt main iron LS blocks for $349. it's all about sales volume. If they knew they could sell 1000's and not 10's the price would come way down.
[Re: sgcuda]
#2537289
08/16/18 05:41 PM
08/16/18 05:41 PM
polyspheric
New York
Low volume = high price. A billet aluminum block to replace my (excellent, safe to at least 1,500 HP) cast iron OEM, no larger bore available, no specific weight saving claimed, is $9,000.
Boffin Emeritus
