Page 3 of 3 1 2 3
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: crankn101] #2536088
08/14/18 11:44 AM
08/14/18 11:44 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I'd run a Late Hemi with a turbo. Stock block and forged crank will hold 1000 HP w/o issue. Stock heads are very good. aftermarket piston/rod for boost. Use a knock off Drag Pac intake. 20 psi should get it easy.
That’s the future right there.
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: crankn101] #2536091
08/14/18 11:45 AM
08/14/18 11:45 AM
New York
polyspheric Offline
polyspheric  Offline
New York
these original blocks can hold more power if the engine is "boosted", is that true
Yes, the cylinder pressure "spike" (BMEP) is lower and more widely distributed than equivalent HP NA.
Many successful turbo race cars don't use fabricated tube headers, but simply use modified stock cast-iron manifolds upside down, reversed front to rear etc. Google around for 1968-70 B/RB manifold choices on turbos including truck, C body etc.
Boffin Emeritus
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: dvw] #2536114
08/14/18 12:30 PM
08/14/18 12:30 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
[quote=Clanton][quote=BradH]What's the budget for this effort?
12 to 15,000$ I would think
I dont really have a budget, I was hoping for 10-12K for the engine or so plus whatever power adder I go with.
For the record, building a 572 or an after market block was never in any of my plans.
Doug
https://www.google.com/amp/s/www.hotrod....rbocharger/amp/
This is friends Dart. Since the article he has had to make quite a few upgrades as he bent the Dana 60 and the bars holding it in the car! As I recall he's been 8.20's.
It's a very mild setup and he drives it all over Wichita.
I have another local friend that parts SRT-8 cars with the 6.1 and an early A-body 'Cuda with this engine and a turbo will be my next project.
'63 Dodge 330
11.19 @ 121 mph
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: crankn101] #2536152
08/14/18 01:50 PM
08/14/18 01:50 PM
IL
furious70 Offline
furious70  Offline
IL
the mythical van BB manifold that you can turn upside down and still put in spark plugs
https://photos.app.goo.gl/UKNYUsEDbEjBAX2b6
https://photos.app.goo.gl/jqp6VFMLvpqT14Bd7
late 50's manifold with generator provision, something I may someday try on a BB single turbo car
https://photos.app.goo.gl/iBbqSgEdoPytKuBg6
on the right, 64/65? BB manifolds that exit behind the last port, might work swapped side for side depending on steering/a arm config
https://photos.app.goo.gl/6JKnRkjkHVd1xSPV9
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: furious70] #2536440
08/14/18 09:55 PM
08/14/18 09:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you want to run NA then you better get a LOT
lighter than you are.. more than likely you
better get lighter than you think
wave
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: GY3] #2536468
08/14/18 10:31 PM
08/14/18 10:31 PM
CO
crankn101 Offline OP
CO
Doug
I have another local friend that parts SRT-8 cars with the 6.1 and an early A-body 'Cuda with this engine and a turbo will be my next project. [quote/]
That thing is BAD!
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: MR_P_BODY] #2536470
08/14/18 10:34 PM
08/14/18 10:34 PM
CO
CO
wave
Im running a power adder
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: dvw] #2537287
08/16/18 05:30 PM
08/16/18 05:30 PM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
Doug
That's what I would do. Well that is what I would do if I did it again
Here is mine on its first run 9.7
500 inch
Procharger
https://www.youtube.com/watch?v=jqMdxvWYyq0&ab_channel=RobKamstra
I needed more injector as I ran it to a 100% duty cycle and the MAP at 100%
Need to head back to see how it does
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: Easiest and or best way to run a 9.5et 70' Roadrunner [Re: Kam*Kuda] #2537411
08/16/18 10:44 PM
08/16/18 10:44 PM
CO
CO
Doug
500 inch
Procharger
Sweet car!
Thats almost exactly what Im looking to build, there is hope after all.
Page 3 of 3 1 2 3
