Re: Easiest and or best way to run a 9.5et 70' Roadrunner
[Re: crankn101]
#2536088
08/14/18 11:44 AM
08/14/18 11:44 AM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I'd run a Late Hemi with a turbo. Stock block and forged crank will hold 1000 HP w/o issue. Stock heads are very good. aftermarket piston/rod for boost. Use a knock off Drag Pac intake. 20 psi should get it easy. That’s the future right there.
[Re: crankn101]
#2536091
08/14/18 11:45 AM
08/14/18 11:45 AM
Posts: 4,210 New York
polyspheric
New York
these original blocks can hold more power if the engine is "boosted", is that true Yes, the cylinder pressure "spike" (BMEP) is lower and more widely distributed than equivalent HP NA.
Many successful turbo race cars don't use fabricated tube headers, but simply use modified stock cast-iron manifolds upside down, reversed front to rear etc. Google around for 1968-70 B/RB manifold choices on turbos including truck, C body etc.
Boffin Emeritus
[Re: dvw]
#2536114
08/14/18 12:30 PM
08/14/18 12:30 PM
Posts: 4,697 Wichita
GY3
Wichita
[quote=Clanton][quote=BradH]What's the budget for this effort? 12 to 15,000$ I would think I dont really have a budget, I was hoping for 10-12K for the engine or so plus whatever power adder I go with. For the record, building a 572 or an after market block was never in any of my plans. I'd run a Late Hemi with a turbo. Stock block and forged crank will hold 1000 HP w/o issue. Stock heads are very good. aftermarket piston/rod for boost. Use a knock off Drag Pac intake. 20 psi should get it easy. Doug https://www.google.com/amp/s/www.hotrod....rbocharger/amp/This is friends Dart. Since the article he has had to make quite a few upgrades as he bent the Dana 60 and the bars holding it in the car! As I recall he's been 8.20's. It's a very mild setup and he drives it all over Wichita. I have another local friend that parts SRT-8 cars with the 6.1 and an early A-body 'Cuda with this engine and a turbo will be my next project.
[Re: furious70]
#2536440
08/14/18 09:55 PM
08/14/18 09:55 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If you want to run NA then you better get a LOT lighter than you are.. more than likely you better get lighter than you think
[Re: GY3]
#2536468
08/14/18 10:31 PM
08/14/18 10:31 PM
Posts: 36 CO
crankn101
CO
https://www.google.com/amp/s/www.hotrod....rbocharger/amp/This is friends Dart. Since the article he has had to make quite a few upgrades as he bent the Dana 60 and the bars holding it in the car! As I recall he's been 8.20's. It's a very mild setup and he drives it all over Wichita. I have another local friend that parts SRT-8 cars with the 6.1 and an early A-body 'Cuda with this engine and a turbo will be my next project. [quote/] That thing is BAD!
[Re: MR_P_BODY]
#2536470
08/14/18 10:34 PM
08/14/18 10:34 PM
Posts: 36 CO
crankn101
CO
If you want to run NA then you better get a LOT lighter than you are.. more than likely you better get lighter than you think Im running a power adder
[Re: dvw]
#2537287
08/16/18 05:30 PM
08/16/18 05:30 PM
Posts: 4,244 Canada
Kam*Kuda
Canada
That's what I would do. Well that is what I would do if I did it again Here is mine on its first run 9.7 500 inch Procharger https://www.youtube.com/watch?v=jqMdxvWYyq0&ab_channel=RobKamstraI needed more injector as I ran it to a 100% duty cycle and the MAP at 100% Need to head back to see how it does
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
[Re: Kam*Kuda]
#2537411
08/16/18 10:44 PM
08/16/18 10:44 PM
Posts: 36 CO
crankn101
CO
That's what I would do. Well that is what I would do if I did it again Here is mine on its first run 9.7 500 inch Procharger https://www.youtube.com/watch?v=jqMdxvWYyq0&ab_channel=RobKamstraI needed more injector as I ran it to a 100% duty cycle and the MAP at 100% Need to head back to see how it does Sweet car! Thats almost exactly what Im looking to build, there is hope after all.
