REACTION SHAFT #2536366
08/14/18 07:47 PM
08/14/18 07:47 PM
ontario canada
426lloyd Offline OP
426lloyd  Offline OP
ontario canada
Can a 1970 REACTION SHAFT from a 904 transmission 27 spline be put into a 1966 18 spline without changing anything else or what else may have to be changed.The 1966 is rebuilt now but needs the 27 spline for converter. Thanks
Re: REACTION SHAFT [Re: 426lloyd] #2536507
08/14/18 11:58 PM
08/14/18 11:58 PM
ontario canada
426lloyd Offline OP
426lloyd  Offline OP
ontario canada
Bump I am sure John could answer this
Re: REACTION SHAFT [Re: 426lloyd] #2536510
08/15/18 12:00 AM
08/15/18 12:00 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
PM John
IIRC, and if you are talking about the input shaft I believe you need to change the front pump to the newer setup as well, but it's been 25+ years so it's getting fuzzy to me.
Don't be the exception.
Re: REACTION SHAFT [Re: 426lloyd] #2536522
08/15/18 12:15 AM
08/15/18 12:15 AM
ontario canada
426lloyd Offline OP
426lloyd  Offline OP
ontario canada
Correct I should of said reaction SHAFT and pump
Re: REACTION SHAFT [Re: 426lloyd] #2536761
08/15/18 02:27 PM
08/15/18 02:27 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
18 and 27 are the input shaft spline counts. When changing to the 27-spline input shaft you must also change to the '68-later reaction shaft support.
Re: REACTION SHAFT [Re: 426lloyd] #2537345
08/16/18 07:31 PM
08/16/18 07:31 PM
ontario canada
426lloyd Offline OP
426lloyd  Offline OP
ontario canada
Thank you
