What spark plug are you using in your stroked Hemi
#2536207
08/14/18 03:23 PM
08/14/18 03:23 PM
Posts: 3,392 cheshire, ct
davesmopars
cheshire, ct
What spark plug are you using in your stroked HemI street car pump gas thanks
Keeper of the 440 M code Cuda registry mcodecuda@yahoo.com
Re: What spark plug are you using in your stroked Hemi
[Re: davesmopars]
#2536663
08/15/18 11:25 AM
08/15/18 11:25 AM
Posts: 13,361 Marion, South Carolina [><]
an8sec70cuda
NGK 4554 (R5671A-8) in my 11:1 pump gas (93) 572" Hemi. I use these when I run it NA and on the street. I throw a colder set in it for nitrous use.
[Re: davesmopars]
#2536715
08/15/18 01:07 PM
08/15/18 01:07 PM
davesmopars
cheshire, ct
It's a 604 aluminum head 10.2 compression it this make a difference
I have written on paper work I think this what it says real bad writing NGK NY9 NGK N 11 (i think)
Champion RN11Y
Then say start with 9
This was written in the notes, very messy hard to read
[Re: davesmopars]
#2536727
08/15/18 01:28 PM
08/15/18 01:28 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
Champion numbers tell you about the plugs, if you wanted to start with RN9YC,R= resistor plug, N=13/16 socket size with 3/4 inch thread length, 9= the heat range , bigger #s are hotter, smaller are colder in Champion plugs Y= extended spark plug ground strap, C=copper core. On your deal I would start with a cold plug like the RN9YC or the smaller 5/8 socket size RC9YC plugs IHTHs
[Re: Cab_Burge]
#2536786
08/15/18 03:30 PM
08/15/18 03:30 PM
Posts: 4,457 Washington
madscientist
Washington
Champion numbers tell you about the plugs, if you wanted to start with RN9YC,R= resistor plug, N=13/16 socket size with 3/4 inch thread length, 9= the heat range , bigger #s are hotter, smaller are colder in Champion plugs Y= extended spark plug ground strap, C=copper core. On your deal I would start with a cold plug like the RN9YC or the smaller 5/8 socket size RC9YC plugs IHTHs I agree with cab. No need to mess with the N series Champion plug. Just use the C series and that way you get the 5/8 hex instead of the big, clunky 13/16 hex. If you think you need the 11 heat range Champion, I don't think they have that in the C series. Don't have my catalog handy but if that's what you need, you can use the RC12YC instead. At 10.2:1 compression and pump gas my guess is you'll need the 12 but I'd start with the 9 and work with it. Easier to tune up to a warmer plug than it is to start on the warm side and have issues. IOW, I start colder and then use a warmer plug if I need it.
[Re: davesmopars]
#2536798
08/15/18 04:07 PM
08/15/18 04:07 PM
davesmopars
cheshire, ct
And this is why I ask. thanks
Looks like Champion is the choice. I will start with the RC9YC plugs
[Re: davesmopars]
#2538488
08/19/18 11:54 AM
08/19/18 11:54 AM
davesmopars
cheshire, ct
What do you recommend for a gap.
[Re: davesmopars]
#2538528
08/19/18 01:23 PM
08/19/18 01:23 PM
Cab_Burge
What ignition and coil are you using? If a MSD race 7 box with the proper coil set them at .045, if a MSD 6 with a regular coil try .035
