What spark plug are you using in your stroked Hemi #2536207
08/14/18 03:23 PM
08/14/18 03:23 PM
cheshire, ct
davesmopars Offline OP
cheshire, ct
What spark plug are you using in your stroked HemI street car pump gas
thanks
Keeper of the 440 M code Cuda registry
mcodecuda@yahoo.com
Re: What spark plug are you using in your stroked Hemi [Re: davesmopars] #2536240
08/14/18 04:16 PM
08/14/18 04:16 PM
I would start with either Champion RC9YC or Autolite #3911 or 3910 is(colder than 3911) or Autolite 3923 or 3924 scope
Any of them will work with iron heads and up to 11.5 to 1 compression ratio on 91 octane pump swill scope
Re: What spark plug are you using in your stroked Hemi [Re: davesmopars] #2536663
08/15/18 11:25 AM
08/15/18 11:25 AM
an8sec70cuda Offline
NGK 4554 (R5671A-8) in my 11:1 pump gas (93) 572" Hemi. I use these when I run it NA and on the street. I throw a colder set in it for nitrous use.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: What spark plug are you using in your stroked Hemi [Re: davesmopars] #2536715
08/15/18 01:07 PM
08/15/18 01:07 PM
cheshire, ct
cheshire, ct
It's a 604 aluminum head 10.2 compression it this make a difference
I have written on paper work I think this what it says real bad writing
NGK NY9
NGK N 11 (i think)
Champion RN11Y
Then say start with 9
This was written in the notes, very messy hard to read
mcodecuda@yahoo.com
Re: What spark plug are you using in your stroked Hemi [Re: davesmopars] #2536727
08/15/18 01:28 PM
08/15/18 01:28 PM
Champion numbers tell you about the plugs, if you wanted to start with RN9YC,R= resistor plug, N=13/16 socket size with 3/4 inch thread length, 9= the heat range , bigger #s are hotter, smaller are colder in Champion plugs up Y= extended spark plug ground strap, C=copper core.
On your deal I would start with a cold plug like the RN9YC or the smaller 5/8 socket size RC9YC plugs scope up
IHTHs
Re: What spark plug are you using in your stroked Hemi [Re: Cab_Burge] #2536786
08/15/18 03:30 PM
08/15/18 03:30 PM
Washington
madscientist Offline
Washington
IHTHs
I agree with cab. No need to mess with the N series Champion plug. Just use the C series and that way you get the 5/8 hex instead of the big, clunky 13/16 hex.
If you think you need the 11 heat range Champion, I don't think they have that in the C series. Don't have my catalog handy but if that's what you need, you can use the RC12YC instead.
At 10.2:1 compression and pump gas my guess is you'll need the 12 but I'd start with the 9 and work with it. Easier to tune up to a warmer plug than it is to start on the warm side and have issues. IOW, I start colder and then use a warmer plug if I need it.
Re: What spark plug are you using in your stroked Hemi [Re: davesmopars] #2536798
08/15/18 04:07 PM
08/15/18 04:07 PM
cheshire, ct
cheshire, ct
And this is why I ask. thanks
Looks like Champion is the choice.
I will start with the RC9YC plugs
mcodecuda@yahoo.com
Re: What spark plug are you using in your stroked Hemi [Re: davesmopars] #2538488
08/19/18 11:54 AM
08/19/18 11:54 AM
cheshire, ct
cheshire, ct
What do you recommend for a gap.
mcodecuda@yahoo.com
Re: What spark plug are you using in your stroked Hemi [Re: davesmopars] #2538528
08/19/18 01:23 PM
08/19/18 01:23 PM
What ignition and coil are you using?
If a MSD race 7 box with the proper coil set them at .045, if a MSD 6 with a regular coil try .035 shruggy
Re: What spark plug are you using in your stroked Hemi [Re: davesmopars] #2538905
08/20/18 10:40 AM
08/20/18 10:40 AM
Northeast Indiana
73DAD Offline
73DAD  Offline
Northeast Indiana
RC12YC in mine, gasket left on, 10:1 iron heads. Sheepishly admit that I've never gapped them.
