Page 3 of 3 1 2 3
Re: The mighty 318 [Re: quickd100] #2535270
08/12/18 08:28 PM
08/12/18 08:28 PM
CO
crankn101 Offline
crankn101  Offline
CO
Cool build!
Re: The mighty 318 [Re: quickd100] #2535331
08/12/18 10:09 PM
08/12/18 10:09 PM
New York
polyspheric Offline
polyspheric  Offline
New York
keeping the hose between the turbo and the carb hat from blowing off, I need to pick up better clamps.
The clamp isn't the problem (been there, done that), you need a bead rolled into each end of the tube.
Boffin Emeritus
Re: The mighty 318 [Re: quickd100] #2535383
08/12/18 11:48 PM
08/12/18 11:48 PM
Granbury TX
Prochargedmopar Offline
Granbury TX
I’m reading this to my 15yo son and he is smiling ear to ear thinking about the possibilities with his 72 318.
Good work and results!!!
"Old" member Registered: Sep 2001
Lost my credentials, I'm Back!! LOL
71 Ply Satellite Procharged
73 Dodge Dart Swinger
73 Ford F-100 390/Sniper efi/back to carb
01 Town and Country Limited
08 Dodge 2500 6.7 5" Deleted
02 Mercedes C230K
19 Camry
Re: The mighty 318 [Re: quickd100] #2535388
08/13/18 12:01 AM
08/13/18 12:01 AM
nielsville, minn.
Q
quickd100 Offline OP
Q
nielsville, minn.
Once I read your response Jeff I realized that a bead makes perfect sense, thank you.
Greg, I file fit the rings and opened them up to .035+. All the pistons I have hurt have been destroyed by detonation. One set broke Every skirt off every piston. I'm still trying to figure how it can rattle a piston that hard in a properly clearance bore
Sometime this week I'm going to try a 750 Eddy on it.
Re: The mighty 318 [Re: quickd100] #2535450
08/13/18 03:16 AM
08/13/18 03:16 AM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
Originally Posted By quickd100
...One set broke Every skirt off every piston. I'm still trying to figure how it can rattle a piston that hard in a properly clearance bore ...
Wrist pin offset. It's great for preventing piston slap in low performance engines but...
Re: The mighty 318 [Re: quickd100] #2537852
08/17/18 09:01 PM
08/17/18 09:01 PM
jersey
Spaceman Spiff Offline
jersey
just listened to the pod cast from " uncle tony's Garage" that you were on.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: The mighty 318 [Re: Spaceman Spiff] #2538021
08/18/18 08:56 AM
08/18/18 08:56 AM
nielsville, minn.
Q
Q
nielsville, minn.
Yep, that was me the funny sounding guy. If you've ever seen the movie "Fargo" some of us really do talk like that. I grew up and still live about 50 miles nort' of Fargo. coffee
Re: The mighty 318 [Re: quickd100] #2538061
08/18/18 11:44 AM
08/18/18 11:44 AM
moparx Offline
moparx  Offline
you don't have any wood chippers around, right ? nervous
beer
Re: The mighty 318 [Re: quickd100] #2538107
08/18/18 01:16 PM
08/18/18 01:16 PM
nielsville, minn.
Q
Q
nielsville, minn.
Nah, too messy, feed 'em to the hogs.
Re: The mighty 318 [Re: quickd100] #2538245
08/18/18 09:19 PM
08/18/18 09:19 PM
PA
Scully Offline
Scully  Offline
PA
Well it didn't go very well today. I found a mouse had camped out in my phase convertor and I had to do some backyard engineering to get my water pump running. All the while my phase convertor was smoking and sparking.
Anyway, naturally aspirated it didn't really gain anything so I richened up the secondaries and hooked up the turbo and dropped the timing back to 20°. It ran great until the clamp on the tube between the carb hat and the turbo said uncle at 4252 rpm. I also blew an O-ring on the blowoff valve.
Anyway, it was at 423.1hp&517.4ftlbs@4152 rpm and still going straight up. Boost was at 15.07psi.(I should add that all pulls were done on C14)
I'll have to rewire the phase convertor and pick up some better clamps before I explore the outter limits of the 318.
What size rotary convertor are you using for the dyno and what type of dyno. I recently got a 20 HP motor to build convertor for my SF 901. I may try a 7.5 HP to run my machine shop I'm setting up as I don't think the 5 HP I have now will run the CK 10 properly, I'll find out in a few weeks.
Re: The mighty 318 [Re: quickd100] #2538402
08/19/18 01:46 AM
08/19/18 01:46 AM
nielsville, minn.
Q
Q
nielsville, minn.
The phase convertor just runs the motor for the water pump that feeds the absorber. It's a bank of capacitors that kickstart a 3 phase motor. I've done the same thing just spooling up a 3 phase motor with another single phase motor.
The dyno is a L&S 13" dualrotor water brake. It's good for 2000 ftlbs of input torque.
Re: The mighty 318 [Re: quickd100] #2538660
08/19/18 08:17 PM
08/19/18 08:17 PM
nielsville, minn.
Q
Q
nielsville, minn.
Well I finished testing and tuning. The motor is still in one piece and ready to go back in the truck.
I'm a bit disappointed as I couldn't get it past 520hp and 633ftlbs. The wastegate and blowoff valves wouldnt allow me to go any higher.
I backed the boost down to 14 lbs. The 600 Eddy made 376.1hp@4390 rpm and 459.5ftlbs at13.9 lbs of boost. The 750 Eddy made 409.5hp@4587rpm and 485.7 ftlbs. at 14.04 lbs of boost.
To get the carbs rich enough I ended up removing the secondary jets entirely. I could have drilled and tapped the airbleeds to richened the carbs up but I'm running out of time to screw with it and this worked.
I made about 35 pulls and probably could have made another 35 but there comes a time to say good enough. So the motor went from 229hp naturally aspirated to about the same level as a 413 maxwedge with a little help of a cheap Chinese turbo. If at some point I feel a little 'gamey' it's just a spring change away from another 100hp.
Page 3 of 3 1 2 3
