Dual Snorkel Air Cleaner
#2535119
08/12/18 03:56 PM
08/12/18 03:56 PM
Posts: 4,421 Michigan
MarkZ
Worthy
Worthy
I've been noticing the intake air temp on motor can get upwards of 140 degrees if I'm idling and at speed only gets down to 112 degrees on an 85 degree day. Do you guys think a dual inlet 440 air cleaner would be a restriction on a 512? Thanks.
Re: Dual Snorkel Air Cleaner
[Re: MarkZ]
#2535190
08/12/18 06:05 PM
08/12/18 06:05 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
engine masters did a test on a bunch of filter housings, this was one of them. https://www.dailymotion.com/video/x693421
[Re: Supercuda]
#2535276
08/12/18 08:35 PM
08/12/18 08:35 PM
Posts: 4,681 Wichita
GY3
Wichita
Dual snorkel is a restriction on a 440!
I took mine off, sold it and went to open element.
[Re: GY3]
#2535281
08/12/18 08:42 PM
08/12/18 08:42 PM
Supercuda
About to go away
About to go away
up yours
I took mine off, sold it and went to open element. And enjoyed all the hot air under the hood your engine could handle.
[Re: Supercuda]
#2535299
08/12/18 09:13 PM
08/12/18 09:13 PM
GY3
Wichita
I took mine off, sold it and went to open element. And enjoyed all the hot air under the hood your engine could handle. How is that different than a dual snorkel?! Both pulled underhood air in my case.
[Re: MarkZ]
#2535400
08/13/18 12:45 AM
08/13/18 12:45 AM
Supercuda
About to go away
About to go away
up yours
Well the dual snorkle I had ran a duct to the fenderwell and drew cold air from there, but it wasn't on a 440. It was an M body cop car and it was factory.
