I've been noticing the intake air temp on motor can get upwards of 140 degrees if I'm idling and at speed only gets down to 112 degrees on an 85 degree day. Do you guys think a dual inlet 440 air cleaner would be a restriction on a 512? Thanks.
1987 Fifth Avenue - 512/518/D60
