Re: Opinions on exhaust crossover
[Re: MidPenMopar]
#2534482
08/11/18 08:27 AM
08/11/18 08:27 AM
Posts: 20,630 in a cattle trailer down by th...
Guitar Jones
Personally I'm all for making my vehicles easier to work on rather than try to get every last ounce of performance. How much can you really use on a street car anyway?
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Guitar Jones]
#2534529
08/11/18 12:19 PM
08/11/18 12:19 PM
Posts: 36,840 South San Francisco, Californi...
MidPenMopar
Looking for fun? Keep looking
Personally I'm all for making my vehicles easier to work on rather than try to get every last ounce of performance. How much can you really use on a street car anyway? That was my thinking too, as i bought some of those chambered mufflers and will be redoing the exhaust system. The 3 inch H-pipe i have now hangs down and scrapes over speed bumps. So i was thinking of just going with straight dual pipes this time. I am going back to 2.5 pipes as well. Stu
[Re: MidPenMopar]
#2534540
08/11/18 12:47 PM
08/11/18 12:47 PM
Posts: 2,255 IL
furious70
IL
Engine masters on motortrendondemand tested, not enough difference in power for the hassle. Sound was a bit different.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: MidPenMopar]
#2534549
08/11/18 01:14 PM
08/11/18 01:14 PM
Posts: 15,831 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I've never been able to notice a sound difference despite the claims, nor any seat of the pants dyno difference.
Facts are stubborn things.
[Re: MidPenMopar]
#2534623
08/11/18 04:04 PM
08/11/18 04:04 PM
Posts: 2,806 Northern NJ
StukaJU87
Northern NJ
How about running straight duals out the back....no mufflers? I currently have mufflers with no crossover and they sound great, but the drivers side has a loose baffle or something and rattles a bit.
Was thinking about having the muffler shop just replace the mufflers with pipe.
Scott
1969 Super Bee, 383/4 speed
[Re: MidPenMopar]
#2534639
08/11/18 04:35 PM
08/11/18 04:35 PM
Posts: 29,650 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
C'mon Stu. Side pipes with no crossover. You know you want to.....
[Re: StukaJU87]
#2534647
08/11/18 04:50 PM
08/11/18 04:50 PM
Posts: 8,393 Highland, MI.
Sunroofcuda
Highland, MI.
Was thinking about having the muffler shop just replace the mufflers with pipe. During exhaust experimentation with Viper development, they straight-piped one & lost about 30 HP & the engine temp increased also about 30 degrees. They let things cool down & installed some mufflers. Everything came back into normal range. For a street car, it's my opinion you need an expansion chamber in the system. Plus, straight pipes don't do ANY tuning for sound, nor do glasspacks. Stu, for what it's worth, on a dual exhaust I prefer an H-pipe vs. an X-pipe. The crossover should be .75 the diameter of the system. On a 2.5" dual, the crossover should be approx. 2" according to the math. Helps to equalize pressure between banks & mellows the sound a little.
[Re: MidPenMopar]
#2534653
08/11/18 05:09 PM
08/11/18 05:09 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
A key point is location of the crossover as well.
[Re: Sunroofcuda]
#2534696
08/11/18 06:20 PM
08/11/18 06:20 PM
StukaJU87
Northern NJ
Was thinking about having the muffler shop just replace the mufflers with pipe. During exhaust experimentation with Viper development, they straight-piped one & lost about 30 HP & the engine temp increased also about 30 degrees. They let things cool down & installed some mufflers. Everything came back into normal range. For a street car, it's my opinion you need an expansion chamber in the system. Plus, straight pipes don't do ANY tuning for sound, nor do glasspacks. Stu, for what it's worth, on a dual exhaust I prefer an H-pipe vs. an X-pipe. The crossover should be .75 the diameter of the system. On a 2.5" dual, the crossover should be approx. 2" according to the math. Helps to equalize pressure between banks & mellows the sound a little. Thank you Sunroofcuda, I will just have the muffler replaced.
Scott
[Re: BigBlockMopar]
#2535322
08/12/18 09:48 PM
08/12/18 09:48 PM
Sunroofcuda
Highland, MI.
An X-pipe will remove the typical 'stereo' exhaust pulses coming from the tubes. It will sound more like a modern V8-car. The H-pipe retains some of that 'old' V8 muscle car sound better imo.
Agreed - I just like the way an H-pipe sounds better than an X. Stu, as far as textbook "proper" diameter, 2" would be optimum for the crossover. However, since you already have a crossover, I don't think it would be worth the time & trouble to change that out. Might make no difference at all from a performance standpoint.
[Re: Sunroofcuda]
#2535398
08/13/18 12:39 AM
08/13/18 12:39 AM
Posts: 5,305 Land 'O Lakes
RoadRunnerLuva
Land 'O Lakes
Doesn't an "H pipe" or crossover pipe also help give MORE low end torque to the engine, as opposed to just using dual straight pipe? That is what I was schooled on, back in the day, for (street) cars.
Plymouth Makes It!
[Re: RoadRunnerLuva]
#2535477
08/13/18 07:21 AM
08/13/18 07:21 AM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
Doesn't an "H pipe" or crossover pipe also help give MORE low end torque to the engine, as opposed to just using dual straight pipe? That is what I was schooled on, back in the day, for (street) cars. An H or X was proven to make some extra torque over a straight pipe, but in general not quite worth the hassle by Freiburg/Dulcich/Westec Dyno in an Engine Master video on YouTube. (This was before they put every behind a pay-wall and hardly no-one gets to watch their stuff anymore.) Found the video on DailyMotion instead: https://www.dailymotion.com/video/x5s8nr8In short: Straight pipe - Torque / Horsepower 366 / 363hp H-pipe370 / 361hp X-pipe370 / 362hp
