Opinions on exhaust crossover #2534470
08/11/18 03:28 AM
08/11/18 03:28 AM
South San Francisco, Californi...
MidPenMopar Offline OP
Looking for fun? Keep looking
What is the consensus about having an H-pipe, an X-pipe or just going with straight dual pipes and no crossover at all?
It seems without a crossover tube working on the underside of the drive train would be so much easier.
Any thoughts on this?
Thank you
Stu
Re: Opinions on exhaust crossover [Re: MidPenMopar] #2534472
08/11/18 04:10 AM
08/11/18 04:10 AM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
There is nothing wrong with straight dual exhaust, but your are leaving some power on the table and will have a little noisier exhaust without an x or h. X is best if it is workable.
Re: Opinions on exhaust crossover [Re: MidPenMopar] #2534482
08/11/18 08:27 AM
08/11/18 08:27 AM
Guitar Jones Online laugh2
Personally I'm all for making my vehicles easier to work on rather than try to get every last ounce of performance. How much can you really use on a street car anyway?
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Opinions on exhaust crossover [Re: Guitar Jones] #2534490
08/11/18 09:12 AM
08/11/18 09:12 AM
Locomotion Offline
Locomotion  Offline
I have a TTI X-pipe in my 3" full exhaust that ends at the rear end housing on my race cars. The "X" ends up at the end of the tailshaft and there is plenty of room to drop the trans pan for service. I had to "ding" the "X" to insure clearance to the driveshaft loop, but it did help performance a bit. The only down-side I can see with the "X" is that I have to drop the exhaust system to change the trans. Gotta watch the straight pipe routing whether you have an "X" or not.
Re: Opinions on exhaust crossover [Re: Guitar Jones] #2534529
08/11/18 12:19 PM
08/11/18 12:19 PM
That was my thinking too, as i bought some of those chambered mufflers and will be redoing the exhaust system. The 3 inch H-pipe i have now hangs down and scrapes over speed bumps. So i was thinking of just going with straight dual pipes this time. I am going back to 2.5 pipes as well.
Stu
Re: Opinions on exhaust crossover [Re: MidPenMopar] #2534540
08/11/18 12:47 PM
08/11/18 12:47 PM
IL
furious70 Offline
furious70  Offline
IL
Engine masters on motortrendondemand tested, not enough difference in power for the hassle. Sound was a bit different.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Opinions on exhaust crossover [Re: furious70] #2534544
08/11/18 01:03 PM
08/11/18 01:03 PM
Thank you for the input!
Re: Opinions on exhaust crossover [Re: MidPenMopar] #2534549
08/11/18 01:14 PM
08/11/18 01:14 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I've never been able to notice a sound difference despite the claims, nor any seat of the pants dyno difference.
Facts are stubborn things.
Re: Opinions on exhaust crossover [Re: MidPenMopar] #2534623
08/11/18 04:04 PM
08/11/18 04:04 PM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
How about running straight duals out the back....no mufflers? I currently have mufflers with no crossover and they sound great, but the drivers side has a loose baffle or something and rattles a bit.
Was thinking about having the muffler shop just replace the mufflers with pipe.
Scott
1969 Super Bee, 383/4 speed
Re: Opinions on exhaust crossover [Re: MidPenMopar] #2534637
08/11/18 04:34 PM
08/11/18 04:34 PM
CA
crackedback Online content
crackedback  Online Content
CA
Every car and combination is different.
Without testing each combo, it's a crapshoot as to whether one has benefits over the others.
Myron has the data and it works on his car.
Re: Opinions on exhaust crossover [Re: MidPenMopar] #2534639
08/11/18 04:35 PM
08/11/18 04:35 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
C'mon Stu.
Side pipes with no crossover.
You know you want to..... wink
Re: Opinions on exhaust crossover [Re: StukaJU87] #2534647
08/11/18 04:50 PM
08/11/18 04:50 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
During exhaust experimentation with Viper development, they straight-piped one & lost about 30 HP & the engine temp increased also about 30 degrees. They let things cool down & installed some mufflers. Everything came back into normal range. For a street car, it's my opinion you need an expansion chamber in the system. Plus, straight pipes don't do ANY tuning for sound, nor do glasspacks. Stu, for what it's worth, on a dual exhaust I prefer an H-pipe vs. an X-pipe. The crossover should be .75 the diameter of the system. On a 2.5" dual, the crossover should be approx. 2" according to the math. Helps to equalize pressure between banks & mellows the sound a little.
Re: Opinions on exhaust crossover [Re: MidPenMopar] #2534653
08/11/18 05:09 PM
08/11/18 05:09 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
A key point is location of the crossover as well.
Don't be the exception.
Re: Opinions on exhaust crossover [Re: Sunroofcuda] #2534696
08/11/18 06:20 PM
08/11/18 06:20 PM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
Thank you Sunroofcuda, I will just have the muffler replaced.
Scott
Re: Opinions on exhaust crossover [Re: Sunroofcuda] #2534774
08/11/18 09:44 PM
08/11/18 09:44 PM
[quote=Sunroofcuda]. Stu, for what it's worth, on a dual exhaust I prefer an H-pipe vs. an X-pipe. The crossover should be .75 the diameter of the system. On a 2.5" dual, the crossover should be approx. 2" according to the math. Helps to equalize pressure between banks & mellows the sound a little. [quote]
Now i have this 3 inch H-pipe with the glass-packs.
When i get your chambered exhaust i was going to dump the H-pipes and run just straight pipes and the chambered exhaust.
So you are recommending i go back to a smaller size diameter crossover, correct??
Sru
Re: Opinions on exhaust crossover [Re: MidPenMopar] #2534778
08/11/18 09:50 PM
08/11/18 09:50 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
An X-pipe will remove the typical 'stereo' exhaust pulses coming from the tubes. It will sound more like a modern V8-car.
The H-pipe retains some of that 'old' V8 muscle car sound better imo.
Re: Opinions on exhaust crossover [Re: BigBlockMopar] #2535322
08/12/18 09:48 PM
08/12/18 09:48 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Agreed - I just like the way an H-pipe sounds better than an X. Stu, as far as textbook "proper" diameter, 2" would be optimum for the crossover. However, since you already have a crossover, I don't think it would be worth the time & trouble to change that out. Might make no difference at all from a performance standpoint.
Re: Opinions on exhaust crossover [Re: Sunroofcuda] #2535398
08/13/18 12:39 AM
08/13/18 12:39 AM
Land 'O Lakes
RoadRunnerLuva Offline
Land 'O Lakes
Doesn't an "H pipe" or crossover pipe also help give MORE low end torque
to the engine, as opposed to just using dual straight pipe? That is what I was schooled on, back in the day, for (street) cars.
Plymouth Makes It!
Re: Opinions on exhaust crossover [Re: MidPenMopar] #2535446
08/13/18 02:53 AM
08/13/18 02:53 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Don't know if this link will work but if it does you can hear my exh when he goes to the back of my car. I use TTI 2" headers and the TTI full exh system with an X-pipe and Dyno-Max Ultra-Flow mufflers. Ron
https://www.facebook.com/moparmusclemag/videos/10155914655157792/
Re: Opinions on exhaust crossover [Re: RoadRunnerLuva] #2535477
08/13/18 07:21 AM
08/13/18 07:21 AM
The Netherlands
The Netherlands
Originally Posted By RoadRunnerLuva
Doesn't an "H pipe" or crossover pipe also help give MORE low end torque to the engine, as opposed to just using dual straight pipe? That is what I was schooled on, back in the day, for (street) cars.
An H or X was proven to make some extra torque over a straight pipe, but in general not quite worth the hassle by Freiburg/Dulcich/Westec Dyno in an Engine Master video on YouTube. (This was before they put every behind a pay-wall and hardly no-one gets to watch their stuff anymore.)
Found the video on DailyMotion instead:
https://www.dailymotion.com/video/x5s8nr8
In short:
Straight pipe - Torque / Horsepower
366 / 363hp
H-pipe
370 / 361hp
X-pipe
370 / 362hp
