mag/LA heads, do they have same valve angle? (18)
#2531884
08/05/18 02:12 PM
08/05/18 02:12 PM
RapidRobert
I wanna cut a junk LA head to make a piston valve notch cutter like what hughes rents. this will be for a mag head LA 360. thank you for your time.
Re: mag/LA heads, do they have same valve angle? (18)
[Re: 451Mopar]
#2532004
08/05/18 07:37 PM
08/05/18 07:37 PM
RapidRobert
Good point, I may be OK as is with some care to not nick anything. there was a utube vid & the guy epoxied a rough piece of sandpaper to a valve face & another guy did what you said, carved a valve to make some cutting edges
[Re: RapidRobert]
#2532301
08/06/18 02:50 PM
08/06/18 02:50 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
same valve angle and placement
[Re: HotRodDave]
#2532390
08/06/18 05:45 PM
08/06/18 05:45 PM
RapidRobert
That's what I needed (wanted!) to hear. thank you.
[Re: RV2]
#2533822
08/09/18 04:08 PM
08/09/18 04:08 PM
dogdays
http://www.lindytools.com/atthpcIsky sells them and I believe also rents them. I believe that Blazin' Bob could make his own. R.
[Re: dogdays]
#2533946
08/09/18 09:22 PM
08/09/18 09:22 PM
RapidRobert
Hey Dog thanks for the vote of confidence.
