mag/LA heads, do they have same valve angle? (18) #2531884
08/05/18 02:12 PM
08/05/18 02:12 PM
RapidRobert Offline OP
I wanna cut a junk LA head to make a piston valve notch cutter like what hughes rents. this will be for a mag head LA 360. thank you for your time.
Re: mag/LA heads, do they have same valve angle? (18) [Re: RapidRobert] #2531899
08/05/18 02:57 PM
08/05/18 02:57 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I think the valve angle is the same. Not sure you need to cut-up a head for the fixture, just don't pull the valve all the way up to the valve seat area. I think the cutter is just a valve that has been slotted and carbide cutter(s) inserted and welded in place?
Re: mag/LA heads, do they have same valve angle? (18) [Re: 451Mopar] #2532004
08/05/18 07:37 PM
08/05/18 07:37 PM
Good point, I may be OK as is with some care to not nick anything. there was a utube vid & the guy epoxied a rough piece of sandpaper to a valve face & another guy did what you said, carved a valve to make some cutting edges
Re: mag/LA heads, do they have same valve angle? (18) [Re: RapidRobert] #2532301
08/06/18 02:50 PM
08/06/18 02:50 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
same valve angle and placement
Re: mag/LA heads, do they have same valve angle? (18) [Re: HotRodDave] #2532390
08/06/18 05:45 PM
08/06/18 05:45 PM
That's what I needed (wanted!) to hear. thank you.
Re: mag/LA heads, do they have same valve angle? (18) [Re: RapidRobert] #2533075
08/07/18 11:18 PM
08/07/18 11:18 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
I think Lisle tools make a fly cutter that you could use with a bare head.
Re: mag/LA heads, do they have same valve angle? (18) [Re: RV2] #2533088
08/07/18 11:40 PM
08/07/18 11:40 PM
I will check it out
Re: mag/LA heads, do they have same valve angle? (18) [Re: RV2] #2533822
08/09/18 04:08 PM
08/09/18 04:08 PM
dogdays Offline
dogdays  Offline
http://www.lindytools.com/atthpc
Isky sells them and I believe also rents them.
I believe that Blazin' Bob could make his own.
R.
Re: mag/LA heads, do they have same valve angle? (18) [Re: dogdays] #2533946
08/09/18 09:22 PM
08/09/18 09:22 PM
Hey Dog thanks for the vote of confidence.
