Bench seat weight
#2533760
08/09/18 01:59 PM
08/09/18 01:59 PM
Posts: 1,935 Grove, OK
hosehead
Grove, OK
I have been looking at putting some A100 buckets in my Belvedere and removing the factory bench. Any of you guys know how much weight I’d be saving? These would have the aluminum super stock brackets and the bench coming out is pretty heavy as I remember. Thanks guys!
63 Plymouth savoy 65 d100 66 dart race project 58 plymouth suburban
Re: Bench seat weight
[Re: hosehead]
#2533856
08/09/18 05:35 PM
08/09/18 05:35 PM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
Probably save you 30-35 pounds with aluminum seat brackets
[Re: fullmetaljacket]
#2533896
08/09/18 06:41 PM
08/09/18 06:41 PM
B3422W5
Portage,michigan
Hose.
My 65' front split folding bench seat weighed a whopping 100 lbs complete with mounting brackets and all. The A-100 seats with A-990 aluminum non adjustable brackets will be around 40 lbs complete for the pair. You are looking at a 55-60 Lbs savings with that alone. Hot rod magazine did an article about lightening up a Duster a while back. The A100 van seats weighed 28 pounds each. Split bench is 95 pounds, typical bench seat is 90. Like i said, more like 30-35 pounds total weight loss with two seats and aluminum brackets over the bench
[Re: hosehead]
#2533901
08/09/18 06:55 PM
08/09/18 06:55 PM
hosehead
Grove, OK
Pretty substantial difference!! Thanks guys!
[Re: hosehead]
#2533953
08/09/18 09:47 PM
08/09/18 09:47 PM
Posts: 3,011 Covington Georgia
RV2
Covington Georgia
I have been looking at putting some A100 buckets in my Belvedere and removing the factory bench. Any of you guys know how much weight I’d be saving? These would have the aluminum super stock brackets and the bench coming out is pretty heavy as I remember. Thanks guys! Kent Smith has a pair ready to go with the aluminum brackets Give him a call 6785429138
[Re: RV2]
#2533970
08/09/18 10:17 PM
08/09/18 10:17 PM
hosehead
Grove, OK
I have been looking at putting some A100 buckets in my Belvedere and removing the factory bench. Any of you guys know how much weight I’d be saving? These would have the aluminum super stock brackets and the bench coming out is pretty heavy as I remember. Thanks guys! Kent Smith has a pair ready to go with the aluminum brackets Give him a call 6785429138 Just bought them!
