Belts-Cam Lock or Latch/Link? #2533319
08/08/18 03:25 PM
08/08/18 03:25 PM
Park Forest, IL
slantzilla Offline OP
Park Forest, IL
Time to order belts for the Valiant. I have never used either type, which one is better/easier to get in and out of?
Thanks! wave
Re: Belts-Cam Lock or Latch/Link? [Re: slantzilla] #2533320
08/08/18 03:28 PM
08/08/18 03:28 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I much prefer the cam lock myself.
68 Barracuda Formula S 340
Re: Belts-Cam Lock or Latch/Link? [Re: slantzilla] #2533324
08/08/18 03:35 PM
08/08/18 03:35 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Personal preference.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Belts-Cam Lock or Latch/Link? [Re: slantzilla] #2533325
08/08/18 03:35 PM
08/08/18 03:35 PM
crabman173
crabman173
Camlock is ten times better you will never do latch again
Re: Belts-Cam Lock or Latch/Link? [Re: ] #2533336
08/08/18 04:23 PM
08/08/18 04:23 PM
Washington
madscientist Offline
Washington
This^^^^^^^^^^^^^^^^^.
Why they even make the latch any more I can't say. It's stupid for sure. My first set was latch. It was worthless.
That was 1986
Re: Belts-Cam Lock or Latch/Link? [Re: slantzilla] #2533345
08/08/18 04:39 PM
08/08/18 04:39 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Cam. The price difference is chump change considering how much easier they make your life. Buy from a company that will reweb/recert them so you don't have to buy a new set in 3 years and throw good hardware away.
Re: Belts-Cam Lock or Latch/Link? [Re: slantzilla] #2533358
08/08/18 05:07 PM
08/08/18 05:07 PM
Park Forest, IL
Park Forest, IL
Thanks guys! Just ordered a set on cam locks. boogie
Re: Belts-Cam Lock or Latch/Link? [Re: slantzilla] #2533379
08/08/18 05:32 PM
08/08/18 05:32 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Why all the hate for the latch link belts
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Belts-Cam Lock or Latch/Link? [Re: pittsburghracer] #2533390
08/08/18 05:52 PM
08/08/18 05:52 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
No kidding. All i have ever used. Unlatch quick, never have to worry if the belts are all hooked up. And frankly cheaper with the same cert and safety rating
Slower to put on, but i never ever rush myself putting on belts and helmet anyhow.
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Belts-Cam Lock or Latch/Link? [Re: slantzilla] #2533394
08/08/18 05:56 PM
08/08/18 05:56 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
^^^^^^ good enough for fighter jets, good enough for me. If they are troublesome, you're uncoordinated, get out of that race car!
Re: Belts-Cam Lock or Latch/Link? [Re: slantzilla] #2533401
08/08/18 06:10 PM
08/08/18 06:10 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
In a tight car, latch belts are a PIA. Have to stack all the ends on the lap belt and get it into the buckle. Yes, I've put them together, only to find that one end was loose when I tried to cinch them down. Then you have to start all over. Cams you can do in the dark or with a helmet on.
Re: Belts-Cam Lock or Latch/Link? [Re: CMcAllister] #2533406
08/08/18 06:15 PM
08/08/18 06:15 PM
PA.
"Little"John
"Little"John
PA.
Never had an issue with latch belts even upside down once. I was just wondering if I missed something.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Belts-Cam Lock or Latch/Link? [Re: pittsburghracer] #2533429
08/08/18 07:05 PM
08/08/18 07:05 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
I've used both since 1978. I've had both types that had horse &&&t designs.
Re: Belts-Cam Lock or Latch/Link? [Re: slantzilla] #2533431
08/08/18 07:10 PM
08/08/18 07:10 PM
Norfolk, NE
Racer33 Offline
Racer33  Offline
Norfolk, NE
I've always had the latch style and its never been a problem. With that being said if my belly gets any bigger the cam lock style may be easier. Lol
Re: Belts-Cam Lock or Latch/Link? [Re: Racer33] #2533436
08/08/18 07:23 PM
08/08/18 07:23 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Lol.... i fixed that issues buying Simpson belts. They are considerably longer than other belts i have had
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Belts-Cam Lock or Latch/Link? [Re: slantzilla] #2533441
08/08/18 07:29 PM
08/08/18 07:29 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Mine are cam locks, a simple twist is all that's needed to get me out. If I'm on fire or upside down I want simple.
Re: Belts-Cam Lock or Latch/Link? [Re: justinp61] #2533459
08/08/18 07:56 PM
08/08/18 07:56 PM
Indianapolis, In. area
BTBelvedere Offline
BTBelvedere  Offline
I drove an ex pro stock Monza for a summer back in the 90's. It had camlock belts.I'll agree that they were very nice to hookup and release,until they didn't release. It's a good thing I wasn't in trouble, just trying to get out of the car. Long story short, there was a set screw that held everything together that backed out. It was under the manufacturer's sticker on the front of the cam. We had no idea it was there or needed to be checked. Never used camlock type after that.
Re: Belts-Cam Lock or Latch/Link? [Re: slantzilla] #2533589
08/09/18 02:24 AM
08/09/18 02:24 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Cam lock is lighter.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Belts-Cam Lock or Latch/Link? [Re: slantzilla] #2533593
08/09/18 03:06 AM
08/09/18 03:06 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Wow, we look like a pretty lazy bunch. My latch takes all of about 8 seconds to belt up. Comes apart just as quick as any cam. Are you guys in some sort of hurry while you’re sitting in the staging lanes? I’ve latched myself into my buddies cam system more than once.... easier? Maybe / maybe not. I think it’s just personal preference.
Re: Belts-Cam Lock or Latch/Link? [Re: Hemi_Joel] #2533598
08/09/18 04:41 AM
08/09/18 04:41 AM
Not the ones I've used confused
I've used both and will use what is in the car.
I do take my time hooking them up with the seat belt adjusted tight with the shoulder harness looser, I do pull them both down as tight as I can get them before pulling out of the staging lanes also up
