Is there a good way to mount a starter into a Lakewood bell? #2533392
08/08/18 05:54 PM
08/08/18 05:54 PM
WI. U.S.A.
DusTed74 Offline OP
DusTed74  Offline OP
WI. U.S.A.
I just got a (Summit #820337)starter and it does not line up with my Lakewood scatter shield. I'm sure that I'm missing something. Your help would be appreciated.
Thanks in advance......Ted
Re: Is there a good way to mount a starter into a Lakewood bell? [Re: DusTed74] #2533393
08/08/18 05:55 PM
08/08/18 05:55 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
What size flywheel do you have?
Re: Is there a good way to mount a starter into a Lakewood bell? [Re: DusTed74] #2533421
08/08/18 06:55 PM
08/08/18 06:55 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Flywheel
130 tooth = 10.5"
143 tooth = 11.0"
Make sure you put the nose cone into the correct hole.
Re: Is there a good way to mount a starter into a Lakewood bell? [Re: DusTed74] #2533424
08/08/18 06:56 PM
08/08/18 06:56 PM
Carson City, Nevada
Carson City, Nevada
Some Lakewoods will not be able to use a 143 tooth flywheel
Re: Is there a good way to mount a starter into a Lakewood bell? [Re: DusTed74] #2533439
08/08/18 07:28 PM
08/08/18 07:28 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Sounds like you need the adapter kit
Re: Is there a good way to mount a starter into a Lakewood bell? [Re: DusTed74] #2533448
08/08/18 07:38 PM
08/08/18 07:38 PM
AndyF Offline
AndyF  Offline
The Lakewood bellhousing has been a piss poor design since day one and they have never fixed it. As pointed out above you need to match the nose cone location with your flywheel size. Lakewood has a cheesy adapter bracket that may or may not fit correctly. On my car I ended up taking the whole thing to a machine shop where they modified the bellhousing so it worked. Here is what mine looked like after we were done with it.
Re: Is there a good way to mount a starter into a Lakewood bell? [Re: Stanton] #2533449
08/08/18 07:39 PM
08/08/18 07:39 PM
Washington
madscientist Offline
Washington
Never heard of the adapter kit. New to me.
I just swear a lot when I put my starter in. I swear at the starter, the headers, the scatter shield, the car, the weather, the dogs, the radio...and anything else I can think of and it just pops right in.
Evidently, that junk doesn't like me swearing at it.
Re: Is there a good way to mount a starter into a Lakewood bell? [Re: madscientist] #2533452
08/08/18 07:46 PM
08/08/18 07:46 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Never had starter issues with mine and my 1972 340 Duster and I even had the BIG starter back then. My big issue was getting it indicated in right. What a pain in the butt working on the ground on ramps.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Is there a good way to mount a starter into a Lakewood bell? [Re: DusTed74] #2533467
08/08/18 08:08 PM
08/08/18 08:08 PM
WI. U.S.A.
DusTed74 Offline OP
DusTed74  Offline OP
WI. U.S.A.
It is a 130 tooth.
Thanks.
Re: Is there a good way to mount a starter into a Lakewood bell? [Re: DusTed74] #2533492
08/08/18 09:37 PM
08/08/18 09:37 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
This is for BB Lakewood scatter shield. I don't know what they do on a smallblock.
They have a bolt in cone that the starter snout pilots into. Two holes where this could go for each flywheel size. See Andy Fs picture, there is a bolt head facing the clutch fork with an empty hole next to it.
Then with the 130 tooth flywheel the top starter bolt goes through the scatter shield. But it doesn't use the lower bolt hole, it uses and adapter pin that bolts to the bellhousing lip and pilots into the lower starter mounting hole. Hoakey but it does work.
I needed these items and I had them copied and fabricated from the originals a guy had. I still have them someplace.
With the 143 tooth flywheel the starter bots directly the the scatter shield through the 2 bolt holes.
Re: Is there a good way to mount a starter into a Lakewood bell? [Re: DusTed74] #2533516
08/08/18 10:41 PM
08/08/18 10:41 PM
WI. U.S.A.
DusTed74 Offline OP
DusTed74  Offline OP
WI. U.S.A.
This is exactly what I thought.
Thank you,I can get from here.
Ted
Re: Is there a good way to mount a starter into a Lakewood bell? [Re: AndyF] #2533524
08/08/18 11:16 PM
08/08/18 11:16 PM
Washington
Washington
I doubt that would ever pass a new certification. Not a big deal if you run 11.50 or slower.
Re: Is there a good way to mount a starter into a Lakewood bell? [Re: DusTed74] #2533562
08/09/18 12:38 AM
08/09/18 12:38 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I have run Lakewood shields since the late 70's. No big deal. 143t flywheel bolts up direct. 130t flywheel, you need an adapter for the lower hole. I've used nothing more than 2 bolts and a piece of flat stock to make my own adapter. I've used a chopped off piece of 4 speed cluster shaft bearing spacer for the centering cone, with a flat washer and nut welded on the end, and then hand file the starter nose to fit.
You guys need to get a grasp on fabricating for performance/racing. If you millennials want stuff to fit off the shelf, buy a Chevy.
[image][/image]
Re: Is there a good way to mount a starter into a Lakewood bell? [Re: DusTed74] #2533828
08/09/18 04:26 PM
08/09/18 04:26 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
I must really have a dinosaur bell, made for the 143 tooth only. Has a hole drilled for starter snout and one set of holes. I'm sure the 1/4" steel has "deteriorated" over the years so it won't pass tech either.
Re: Is there a good way to mount a starter into a Lakewood bell? [Re: DusTed74] #2534551
08/11/18 01:15 PM
08/11/18 01:15 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Have a Lakewood in the 65.Starter fits good with the 143.I have an old Ansen in the garage that Ive thought about using.Dont know if it uses 130 or 143.Bought it for the block plate my Lakewood was missing.Rocky
Chrysler Firepower
Re: Is there a good way to mount a starter into a Lakewood bell? [Re: therocks] #2536932
08/15/18 10:40 PM
08/15/18 10:40 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I have an old Ansen in my Savoy and it's NHRA and AHRA approved how old is that. My old Hays MK XII clutch is SEMA approved work
Gus beer
64 Plymouth Savoy
Dana 60
Re: Is there a good way to mount a starter into a Lakewood bell? [Re: DusTed74] #2542143
08/27/18 08:07 PM
08/27/18 08:07 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
Just a silly question.....would the bell from a 400ci truck fit the same for a 440 ?....they may be cheaper
