Belts-Cam Lock or Latch/Link?
#2533319
08/08/18 03:25 PM
08/08/18 03:25 PM
Posts: 20,207 Park Forest, IL
slantzilla
Park Forest, IL
Time to order belts for the Valiant. I have never used either type, which one is better/easier to get in and out of? Thanks!
Re: Belts-Cam Lock or Latch/Link?
[Re: slantzilla]
#2533320
08/08/18 03:28 PM
08/08/18 03:28 PM
Posts: 8,035 Tulsa OK
Bad340fish
Tulsa OK
I much prefer the cam lock myself.
68 Barracuda Formula S 340
[Re: slantzilla]
#2533325
08/08/18 03:35 PM
08/08/18 03:35 PM
crabman173
crabman173
Camlock is ten times better you will never do latch again
[Re: ]
#2533336
08/08/18 04:23 PM
08/08/18 04:23 PM
Posts: 4,457 Washington
madscientist
Washington
Camlock is ten times better you will never do latch again This^^^^^^^^^^^^^^^^^. Why they even make the latch any more I can't say. It's stupid for sure. My first set was latch. It was worthless. That was 1986
[Re: slantzilla]
#2533345
08/08/18 04:39 PM
08/08/18 04:39 PM
Posts: 11,692 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Cam. The price difference is chump change considering how much easier they make your life. Buy from a company that will reweb/recert them so you don't have to buy a new set in 3 years and throw good hardware away.
[Re: slantzilla]
#2533379
08/08/18 05:32 PM
08/08/18 05:32 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Why all the hate for the latch link belts
[Re: pittsburghracer]
#2533390
08/08/18 05:52 PM
08/08/18 05:52 PM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
Why all the hate for the latch link belts No kidding. All i have ever used. Unlatch quick, never have to worry if the belts are all hooked up. And frankly cheaper with the same cert and safety rating Slower to put on, but i never ever rush myself putting on belts and helmet anyhow.
[Re: slantzilla]
#2533401
08/08/18 06:10 PM
08/08/18 06:10 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
In a tight car, latch belts are a PIA. Have to stack all the ends on the lap belt and get it into the buckle. Yes, I've put them together, only to find that one end was loose when I tried to cinch them down. Then you have to start all over. Cams you can do in the dark or with a helmet on.
[Re: CMcAllister]
#2533406
08/08/18 06:15 PM
08/08/18 06:15 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Never had an issue with latch belts even upside down once. I was just wondering if I missed something.
[Re: Racer33]
#2533436
08/08/18 07:23 PM
08/08/18 07:23 PM
B3422W5
Portage,michigan
I've always had the latch style and its never been a problem. With that being said if my belly gets any bigger the cam lock style may be easier. Lol Lol.... i fixed that issues buying Simpson belts. They are considerably longer than other belts i have had
[Re: slantzilla]
#2533589
08/09/18 02:24 AM
08/09/18 02:24 AM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: slantzilla]
#2533593
08/09/18 03:06 AM
08/09/18 03:06 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Wow, we look like a pretty lazy bunch. My latch takes all of about 8 seconds to belt up. Comes apart just as quick as any cam. Are you guys in some sort of hurry while you’re sitting in the staging lanes? I’ve latched myself into my buddies cam system more than once.... easier? Maybe / maybe not. I think it’s just personal preference.
[Re: Hemi_Joel]
#2533598
08/09/18 04:41 AM
08/09/18 04:41 AM
Posts: 43,292 Bend,OR USA
Cab_Burge
Not the ones I've used I've used both and will use what is in the car. I do take my time hooking them up with the seat belt adjusted tight with the shoulder harness looser, I do pull them both down as tight as I can get them before pulling out of the staging lanes also
