Re: Starter clearance to flywheel
[Re: Neil]
#2533514
08/08/18 10:38 PM
08/08/18 10:38 PM
Posts: 43,214 Bend,OR USA
Cab_Burge
How do you even shim a mopar starter as they don't bolt up perpendicular to the ring gear like GM starters do with a starter pad on the block? You can use the stock starter spacers to get more clearances
[Re: Neil]
#2533800
08/09/18 03:18 PM
08/09/18 03:18 PM
Posts: 25,849 Rio Linda, CA
John_Kunkel
Rio Linda, CA
How do you even shim a mopar starter as they don't bolt up perpendicular to the ring gear like GM starters do with a starter pad on the block? I believe the OP is talking about for/aft clearance, not lateral clearance. The factory dust seal is usually missing and would add .032" to the clearance.
[Re: John_Kunkel]
#2534024
08/10/18 12:55 AM
08/10/18 12:55 AM
Posts: 1,649 Armada MICH.
DUSTER_340
Armada MICH.
John could that be added in addition to the sheet metal shield in front of the bellhousing with a small block?
[Re: DUSTER_340]
#2534206
08/10/18 02:52 PM
08/10/18 02:52 PM
John_Kunkel
Rio Linda, CA
Sure, but it would probably need to be trimmed to fit a small block.
