Starter clearance to flywheel #2533290
08/08/18 02:32 PM
08/08/18 02:32 PM
Armada MICH.
DUSTER_340 Offline OP
Armada MICH.
How much clearance should there be between the starter pinion gear and the flywheel. I have both a new flywheel and a new power master starter (original style) and after installing the starter the pinion gear is very close to the flywheel ring gear. What is the minimum clearance ?
Re: Starter clearance to flywheel [Re: DUSTER_340] #2533297
08/08/18 02:38 PM
08/08/18 02:38 PM
I remember hearing .100 or more on race motors shruggy
Re: Starter clearance to flywheel [Re: Cab_Burge] #2533334
08/08/18 04:14 PM
08/08/18 04:14 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
How do you even shim a mopar starter as they don't bolt up perpendicular to the ring gear like GM starters do with a starter pad on the block?
Re: Starter clearance to flywheel [Re: Neil] #2533514
08/08/18 10:38 PM
08/08/18 10:38 PM
You can use the stock starter spacers to get more clearances scope
Re: Starter clearance to flywheel [Re: Neil] #2533800
08/09/18 03:18 PM
08/09/18 03:18 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I believe the OP is talking about for/aft clearance, not lateral clearance. The factory dust seal is usually missing and would add .032" to the clearance.
Re: Starter clearance to flywheel [Re: John_Kunkel] #2534024
08/10/18 12:55 AM
08/10/18 12:55 AM
Armada MICH.
Armada MICH.
John could that be added in addition to the sheet metal shield in front of the bellhousing with a small block?
Re: Starter clearance to flywheel [Re: DUSTER_340] #2534206
08/10/18 02:52 PM
08/10/18 02:52 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Sure, but it would probably need to be trimmed to fit a small block.
