What year and make had chrome valve covers on B/RB engines. #2532325
08/06/18 03:57 PM
08/06/18 03:57 PM
A727Tflite Offline OP
Can anyone provide info on what cars and engines had factory chrome valve covers?
Best I can recall the 426 Steet Wedge (64 & 65?), the 440 GTX in 67, and 68 383 A Body?
Trying to sort this out, pictures would reallly help if anyone can provide them.
Re: What year and make had chrome valve covers on B/RB engines. [Re: A727Tflite] #2532334
08/06/18 04:21 PM
08/06/18 04:21 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
68 and 69 A-Body 383 for sure, 69 440 A-Body did not. Here is a pic of my 69 GTS before the fire... frown 68 383 GTS had a different passenger valve cover.
JB Rhinehart, Realist
A-Body's RULE!
Re: What year and make had chrome valve covers on B/RB engines. [Re: A727Tflite] #2532348
08/06/18 04:45 PM
08/06/18 04:45 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
'67 L code 440 hp Fury, suspect all similar C bodies had them as well. Gone in '68.
Robert
Re: What year and make had chrome valve covers on B/RB engines. [Re: A727Tflite] #2532384
08/06/18 05:38 PM
08/06/18 05:38 PM
Thanks for the replies. This helps but I have a few others.
I’ll post Pics and maybe that would be easier.
Any idea what was different on the 68 A body passenger side cover? GTS only or 68 A body differed from 69?
Re: What year and make had chrome valve covers on B/RB engines. [Re: A727Tflite] #2532394
08/06/18 06:03 PM
08/06/18 06:03 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I think 67 383 Abody did too. I’ve seen unrestored ones with chrome and factory literature.
Also 1967 440 HP motors in: 1967 GTX, R/T, and Charger
Re: What year and make had chrome valve covers on B/RB engines. [Re: A727Tflite] #2532396
08/06/18 06:06 PM
08/06/18 06:06 PM
DELAWARE
TONY_DAGOSTINO Offline
DELAWARE
64-65 426-S steet wedges did
Re: What year and make had chrome valve covers on B/RB engines. [Re: autoxcuda] #2532434
08/06/18 07:09 PM
08/06/18 07:09 PM
Dallas, Texas
FC7cuda Offline
FC7cuda  Offline
Dallas, Texas
They do.
68 Charger
70 Cuda
Re: What year and make had chrome valve covers on B/RB engines. [Re: A727Tflite] #2532528
08/06/18 10:05 PM
08/06/18 10:05 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
67-68 pass side has a bracket for the heater hose retainer.
69 does not
Re: What year and make had chrome valve covers on B/RB engines. [Re: A727Tflite] #2532544
08/06/18 10:35 PM
08/06/18 10:35 PM
Ok, here is what I have.
If you can identify them please use left to right to show what’s what. Thanks.
Re: What year and make had chrome valve covers on B/RB engines. [Re: A727Tflite] #2532589
08/07/18 12:09 AM
08/07/18 12:09 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
3 re from left, what is under the tape? A hole for a grommet?
On the far right both 4 bolt covers neither one has the clips for the engine wiring, so I think you have 2 drivers side covers there.
2 on far left are 1967 440 HP all B&C bodies. Yes the drivers side has spark plug looms for the b-body even though the wire cannot run there. Seen many original cars with this cover on the drivers side. Mostly LA built cars, some ST. Louis built.
Re: What year and make had chrome valve covers on B/RB engines. [Re: A727Tflite] #2532598
08/07/18 12:44 AM
08/07/18 12:44 AM
The small taped hole is a grommet hole. I should have removed that tape or got closer with the camera.
Re: What year and make had chrome valve covers on B/RB engines. [Re: A727Tflite] #2532606
08/07/18 12:55 AM
08/07/18 12:55 AM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
you could buy some chromed ones from ma mopar back in the day also.. similar if not the same as 64-5 426 S iirc..
Re: What year and make had chrome valve covers on B/RB engines. [Re: ph23vo] #2532718
08/07/18 11:19 AM
08/07/18 11:19 AM
Ontario, Canada
mccannix Online content
mccannix  Online Content
Ontario, Canada
Marine BB motors also came with these valve covers 68-69 although with no wire tab provision, so drivers side used on both sides of engine.
I remember growing up when guys were ordering these for their engines
You could even order them over the counter for marine in 70-71 style, with the two different style valve covers but again no wire tabs.
I have a 440-6 engine that I have a pair of the 71 style valve covers on and they look cool.
I still have these ones from years back.
Note the disclaimer....as if whistling
Re: What year and make had chrome valve covers on B/RB engines. [Re: A727Tflite] #2532770
08/07/18 01:13 PM
08/07/18 01:13 PM
Looks like maybe the marine applications borrowed stufff from production - good to know they may have used the same side covers on an engine.
Re: What year and make had chrome valve covers on B/RB engines. [Re: A727Tflite] #2532895
08/07/18 05:26 PM
08/07/18 05:26 PM
DELAWARE
DELAWARE
the breather stacks on the 64-5 chrome covers meet the flat vc surface
on the 67 + newer vcs, the vc is raised immediately below where the stack meets the vc
and
on the 67 b-body 440 hp cars the left vc doesnt have the clip for the #7 spark plug wire as the a-body cars do have the #7 wire run on top of the vc therefore have the plug wire clips on them
Re: What year and make had chrome valve covers on B/RB engines. [Re: A727Tflite] #2532924
08/07/18 06:19 PM
08/07/18 06:19 PM
More good info - thanks.
Re: What year and make had chrome valve covers on B/RB engines. [Re: A727Tflite] #2533125
08/08/18 01:26 AM
08/08/18 01:26 AM
AndyF Offline
AndyF  Offline
Here is a set of original 426W chrome covers I sold a few weeks ago at a swap meet for $40. They were fairly straight but the chrome was really shot on them. They guy seemed super happy to get them and I was glad to get rid of more stuff.
