70 challenger hard start when hot easy right away or when co #2532026
08/05/18 08:26 PM
08/05/18 08:26 PM
VA
jh27-1970 Offline OP
VA
Hi, any help will be appreciated. 70 challenger with 1982 360, 70 340 intake avs carb, when cold starts ok, immediate restart no problem sit for a few ...crank cark foot half throttle and it fires. friend said gas evaporating out of carb, any remedy?? Also can not let gas fill auto, have to listen and cut off when close or fuel spills all over?? Thanks!
Re: 70 challenger hard start when hot easy right away or when co [Re: jh27-1970] #2532031
08/05/18 08:32 PM
08/05/18 08:32 PM
clarks summit pa
73cuda340 Offline
73cuda340  Offline
clarks summit pa
You can try a carb spacer to help insulate it from heat and keep it cooler. On filling the car with gas, mine does the same thing. I fill it very slow and listen when it gets close. I don't think the newer gas pumps sense the fuel level on the older cars. Maybe from the thicker filler necks on the old cars, not sure.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: 70 challenger hard start when hot easy right away or when co [Re: 73cuda340] #2532035
08/05/18 08:43 PM
08/05/18 08:43 PM
clarks summit pa
73cuda340 Offline
73cuda340  Offline
clarks summit pa
You could also block the heat crossover in the intake manifold to help keep that cooler as well. Depending on what kind of choke you have, it may stay engaged longer though.
Re: 70 challenger hard start when hot easy right away or when co [Re: 73cuda340] #2532037
08/05/18 08:47 PM
08/05/18 08:47 PM
VA
VA
Thanks, It has a 1" spacer on it, Glad its not just me with spilt gas. I wonder if there is an adapter, dose the vent line have anything to do with it?
Re: 70 challenger hard start when hot easy right away or when co [Re: jh27-1970] #2532044
08/05/18 09:09 PM
08/05/18 09:09 PM
clarks summit pa
73cuda340 Offline
73cuda340  Offline
clarks summit pa
For the hard starting or filling the tank? On filling the tank, mine is a 73 with the 4 vents on the front of the tank and I have them running to the vapor separator underneath the car and then vented from there and it still does it.
Re: 70 challenger hard start when hot easy right away or when co [Re: jh27-1970] #2532045
08/05/18 09:11 PM
08/05/18 09:11 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
When fueling, try holding the nozzle upside down (hose up).
Anymore, I never auto fill though, I just hold on & listen.
Re: 70 challenger hard start when hot easy right away or when co [Re: jh27-1970] #2532088
08/05/18 11:12 PM
08/05/18 11:12 PM
Cleveland Ohio
sportfury70 Offline
sportfury70  Offline
Cleveland Ohio
Fuel is boiling in carb due to heat soak. That is reason for hard starting after sitting for a few minutes.
Re: 70 challenger hard start when hot easy right away or when co [Re: jh27-1970] #2532092
08/05/18 11:16 PM
08/05/18 11:16 PM
any remedy??
is non ethanol available
Re: 70 challenger hard start when hot easy right away or when co [Re: RapidRobert] #2532096
08/05/18 11:32 PM
08/05/18 11:32 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
probably not what you want to hear - if a heat spacer and/or blocked heat riser passage doesn't solve your problem then an electric fuel pump is the only absolute solution to hard start due to evaporation .
Re: 70 challenger hard start when hot easy right away or when co [Re: RapidRobert] #2532112
08/06/18 12:10 AM
08/06/18 12:10 AM
VA
VA
Yes non ethanol is available , I will try,,, what about a different carb. did it do this stuff when new?
Re: 70 challenger hard start when hot easy right away or when co [Re: jh27-1970] #2532113
08/06/18 12:15 AM
08/06/18 12:15 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Ethanol boils out a lot quicker than gasoline.
Re: 70 challenger hard start when hot easy right away or when co [Re: jh27-1970] #2532157
08/06/18 06:38 AM
08/06/18 06:38 AM
IN
ahy Offline
ahy  Offline
IN
When new, muscle era MOPARs were often slower starting hot... but not too bad. With EFI blend gas, that boils eaisly, it is a lot worse for MOPAR or any carburated vehicle.
Heat insulation of the carb may help. Different gas may help. An electric fuel pump helps. The electric pump, mounted in the rear where it is cooler, will re-fill the carb bowls quickly for faster start. Still need to hold the throttle open to clear out the extra gas.
I have added electric pump to both of my carburated engines for faster start and also to prevent vapor lock running. Getting some pressure in the fuel before it gets into the hot engine compartment helps a lot.
Re: 70 challenger hard start when hot easy right away or when co [Re: jh27-1970] #2532642
08/07/18 04:03 AM
08/07/18 04:03 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Yes the problem is todays gas is made to run under high pressure in a sealed system, not low pressure in a system open to the atmosphere. In short it just evaporates/boils easier.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
