Re: 70 challenger hard start when hot easy right away or when co
[Re: jh27-1970]
#2532031
08/05/18 08:32 PM
08/05/18 08:32 PM
Posts: 1,176 clarks summit pa
73cuda340
clarks summit pa
You can try a carb spacer to help insulate it from heat and keep it cooler. On filling the car with gas, mine does the same thing. I fill it very slow and listen when it gets close. I don't think the newer gas pumps sense the fuel level on the older cars. Maybe from the thicker filler necks on the old cars, not sure.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
[Re: 73cuda340]
#2532035
08/05/18 08:43 PM
08/05/18 08:43 PM
73cuda340
clarks summit pa
You could also block the heat crossover in the intake manifold to help keep that cooler as well. Depending on what kind of choke you have, it may stay engaged longer though.
[Re: jh27-1970]
#2532044
08/05/18 09:09 PM
08/05/18 09:09 PM
73cuda340
clarks summit pa
For the hard starting or filling the tank? On filling the tank, mine is a 73 with the 4 vents on the front of the tank and I have them running to the vapor separator underneath the car and then vented from there and it still does it.
[Re: RapidRobert]
#2532096
08/05/18 11:32 PM
08/05/18 11:32 PM
Posts: 4,720 Moved to N.E. Tennessee
GomangoCuda
probably not what you want to hear - if a heat spacer and/or blocked heat riser passage doesn't solve your problem then an electric fuel pump is the only absolute solution to hard start due to evaporation .
[Re: jh27-1970]
#2532157
08/06/18 06:38 AM
08/06/18 06:38 AM
Posts: 7,664 IN
ahy
IN
Yes non ethanol is available , I will try,,, what about a different carb. did it do this stuff when new? When new, muscle era MOPARs were often slower starting hot... but not too bad. With EFI blend gas, that boils eaisly, it is a lot worse for MOPAR or any carburated vehicle. Heat insulation of the carb may help. Different gas may help. An electric fuel pump helps. The electric pump, mounted in the rear where it is cooler, will re-fill the carb bowls quickly for faster start. Still need to hold the throttle open to clear out the extra gas. I have added electric pump to both of my carburated engines for faster start and also to prevent vapor lock running. Getting some pressure in the fuel before it gets into the hot engine compartment helps a lot.
[Re: jh27-1970]
#2532642
08/07/18 04:03 AM
08/07/18 04:03 AM
Posts: 4,848 Memphis
HemiRick
Memphis
Yes the problem is todays gas is made to run under high pressure in a sealed system, not low pressure in a system open to the atmosphere. In short it just evaporates/boils easier.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
