Carb experts with Hemi crossram intake. #2530680
08/02/18 09:35 PM
08/02/18 09:35 PM
MI, Lapeer
maximus Offline OP
maximus  Offline OP
MI, Lapeer
I have a Hemi with original magnesium cross-ram intake and new Holley cross-ram carbs. The car starts and idles perfect, good throttle response when car idle in park. The problem. If I give a quick jump of the throttle in gear it sometimes drops down to 600 rpm and comes back up to idle, most of the time it just falls off and stalls. Quick turn of the key and it restarts. What needs to be adjusted or looked at on the carbs to fix this problem? Idle mixture screws are all set at 1 1/2 turns out. Any input appreciated.
Re: Carb experts with Hemi crossram intake. [Re: maximus] #2530682
08/02/18 09:38 PM
08/02/18 09:38 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Usually in my experience if it falls flat on it's face, it's lean, if it blubbers then dies then it's rich............
Re: Carb experts with Hemi crossram intake. [Re: maximus] #2530699
08/02/18 10:14 PM
08/02/18 10:14 PM
Kirkland, Washington
Pacnorthcuda Offline
Are your carbs delivering a pump shot IMMEDIAaTELY as you crack the throttle?
Re: Carb experts with Hemi crossram intake. [Re: Pacnorthcuda] #2530706
08/02/18 10:42 PM
08/02/18 10:42 PM
MI, Lapeer
maximus Offline OP
maximus  Offline OP
MI, Lapeer
Yes it does deliver a quick shot. When I start the engine cold two pumps of the throttle, it gives two good squirts and starts right up.
Re: Carb experts with Hemi crossram intake. [Re: maximus] #2530714
08/02/18 11:02 PM
08/02/18 11:02 PM
AndyF Offline
AndyF  Offline
Cross rams have a lot of volume so you might need to give it a lot of pump shot. Pretty tough setup to tune. Lucky for you you're in a good location to find someone who knows how to tune a cross ram. Should be plenty of old cross ram guys floating around the Detroit area.
Re: Carb experts with Hemi crossram intake. [Re: maximus] #2530944
08/03/18 01:28 PM
08/03/18 01:28 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Are the carbs specific to the engine & manifold?
Do they have power valves?
Boffin Emeritus
Re: Carb experts with Hemi crossram intake. [Re: maximus] #2530986
08/03/18 02:43 PM
08/03/18 02:43 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
600? What's your idle rpm? 600-750 is in the good range. Did you open up the throttle blade past the slot? Could be way past and using the main circuit instead of the idle. Are the back ones shut tight?
Re: Carb experts with Hemi crossram intake. [Re: maximus] #2531023
08/03/18 03:47 PM
08/03/18 03:47 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Turn all the idle screws out (richen) a half-turn at a time to see if it improves.
Re: Carb experts with Hemi crossram intake. [Re: John_Kunkel] #2531051
08/03/18 04:32 PM
08/03/18 04:32 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Good advice and where I usually start. Get a wide band and it's eye opening as to how much affect they have on idle, transition and cruise........... thumbs
Re: Carb experts with Hemi crossram intake. [Re: cudaman1969] #2531169
08/03/18 08:44 PM
08/03/18 08:44 PM
MI, Lapeer
maximus Offline OP
maximus  Offline OP
MI, Lapeer
The motor pulls 14.5 in/vac at idle in intake and uses the factory installed 6.5 power valve. Normal operating idle is 1000rpm.
Re: Carb experts with Hemi crossram intake. [Re: maximus] #2531206
08/03/18 09:45 PM
08/03/18 09:45 PM
New York
polyspheric Offline
polyspheric  Offline
New York
How big are the PVCR?
Boffin Emeritus
