Early A-body alterkation or Other? #2530599
08/02/18 06:37 PM
08/02/18 06:37 PM
junction city oregon
V
viperblue72 Offline OP
V
Greetings. I am considering a aftermarket front on my 66 valiant mostly drag car.
I currently have factory 5on4 discs.
What would the weight savings be on a early a-body?
Can I run a bobs pro fab without the shock towers? Mine are already gone. Also can I keep the factory bolt pattern with the altercation? I think I would like the wider track width as my torsion bars are currently maxed just to make room for the header/tire clearance? Thoughts?
Re: Early A-body alterkation or Other? [Re: viperblue72] #2530618
08/02/18 07:24 PM
08/02/18 07:24 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Look at HemiDenny's stuff.
Re: Early A-body alterkation or Other? [Re: viperblue72] #2530635
08/02/18 08:21 PM
08/02/18 08:21 PM
V
V
Thanks I’m not aware of all of my options and all of the differences.
Re: Early A-body alterkation or Other? [Re: viperblue72] #2530636
08/02/18 08:26 PM
08/02/18 08:26 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
QA1 makes one as well.
Re: Early A-body alterkation or Other? [Re: Biginchmopar] #2530643
08/02/18 08:33 PM
08/02/18 08:33 PM
V
V
Isn’t qa1 just the kmember? I wouldn’t think It would save me anything on a early a if that’s all it is.
Re: Early A-body alterkation or Other? [Re: viperblue72] #2530669
08/02/18 09:05 PM
08/02/18 09:05 PM
S.E. South Dakota !
bigdad Online content
Still Posting A Lot
bigdad  Online Content
Still Posting A Lot
S.E. South Dakota !
I put a Alterkation under my 65 Valiant wagon , its nice fits nice ..
Nothing wrong that I can see , except, I don't like the fact that the main square tube in it is not bent on a mandrel bender..
and, its just a bit wider then others out there
For my 67 B-Body , I bought one from Carl Gerst , if I bought another I would buy it from him .
very helpful, very knowledgeable . calls you back, and his costs less and I THINK it nicer looking
http://gerstsuspensions.com/products/
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Early A-body alterkation or Other? [Re: viperblue72] #2530692
08/02/18 10:07 PM
08/02/18 10:07 PM
gregsdart Offline
gregsdart  Offline
Have you figured the cost of a strut front end? Since your shock towers are gone, i assume you have a cage of some sort, and adapting either a strut or Mustang II would be on my list, and i have built two successful coil over/ rack and pinion front ends on 65 Darts. A long travel setup for anything slower than nines i think would be needed. Double ad justable struts are needed above a certain power level
Re: Early A-body alterkation or Other? [Re: viperblue72] #2530739
08/02/18 11:35 PM
08/02/18 11:35 PM
cheshire, ct
davesmopars Offline
davesmopars  Offline
cheshire, ct
HDK suspension
Keeper of the 440 M code Cuda registry
mcodecuda@yahoo.com
Re: Early A-body alterkation or Other? [Re: viperblue72] #2530845
08/03/18 10:05 AM
08/03/18 10:05 AM
Pgh, PA
Bull1tt Offline
Bull1tt  Offline
Pgh, PA
what he said... HDK
Re: Early A-body alterkation or Other? [Re: Bull1tt] #2530879
08/03/18 11:26 AM
08/03/18 11:26 AM
St.Pete,Florida
lancer493 Offline
lancer493  Offline
St.Pete,Florida
If this car is truly just a drag car my vote is a strut front end.Bite the bullet now, as I regret not going that route with my tube-chassis Lancer.
It has a fabbed a-arm coil-over set-up.With a Megablock, dana rear wheelie bars,and additonal safety equipment for performance expectations,things get heavier really fast. I am constantly working at weight reduction. Just look at how fast some of the lighter small-block cars are running,ie:pittsburgracers Duster and numerous others. High horsepower, heavy cars BREAK PARTS! This area is,regretfully, the place I should have used better judgement.
Re: Early A-body alterkation or Other? [Re: viperblue72] #2530932
08/03/18 12:57 PM
08/03/18 12:57 PM
Texas
RustyM Offline
RustyM  Offline
Texas
We use Carl Gerst- Gerst Suspensions.
No issues, answers phone, returns phone calls, quality products.
Re: Early A-body alterkation or Other? [Re: viperblue72] #2530974
08/03/18 02:26 PM
08/03/18 02:26 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
I'm sure you will spend almost as much going with an aftermarket front that you would spend going with struts. If you have any build skill at all you could use your stock frame rails and build your own k for your struts and rack & pinion. You would have excellent suspension at lower weight.
Re: Early A-body alterkation or Other? [Re: bigdad] #2531130
08/03/18 07:30 PM
08/03/18 07:30 PM
V
V
Do you know the weight difference between the factory stuff and alternation?
Re: Early A-body alterkation or Other? [Re: viperblue72] #2531153
08/03/18 08:13 PM
08/03/18 08:13 PM
S.E. South Dakota !
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
I think it would be somewhere around 50 lbs , most of it would be the drums to disc brakes
My Belvedere drives like a go cart now, its great
Re: Early A-body alterkation or Other? [Re: viperblue72] #2531266
08/03/18 11:25 PM
08/03/18 11:25 PM
Medina, OH
dart440_72 Offline
dart440_72  Offline
Medina, OH
I have one from HemiDenny as well. Car is straight as an arrow and super stable at speed. Google HDK K members
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
Re: Early A-body alterkation or Other? [Re: viperblue72] #2532636
08/07/18 03:05 AM
08/07/18 03:05 AM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
Nothin wrong with the RMS AlterKation. Bill is an excellent guy, he answers his phone too. I usually PM him on facebook and he replies almost instantly. I've talked to him @ 10:00 at night. That's damn good service.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: Early A-body alterkation or Other? [Re: viperblue72] #2532748
08/07/18 12:21 PM
08/07/18 12:21 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
After several other front end types used, I can say with confidence, you cannot go wrong with AlterK. They fit, they work, and you can go plenty fast on them.
Re: Early A-body alterkation or Other? [Re: viperblue72] #2533166
08/08/18 07:57 AM
08/08/18 07:57 AM
Mo.
racerx Online work
racerx  Online Work
Mo.
Surprise....no one has mention Bob's profab, dont' he frontends for a-bodys?
