Re: Trick Flow 270 heads rocker arm choices?
[Re: viperblue72]
#2530619
08/02/18 07:34 PM
08/02/18 07:34 PM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
I run the Crane Gold 1.5 on mine . If you can still find them
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: viperblue72]
#2530685
08/02/18 09:43 PM
08/02/18 09:43 PM
Posts: 14,504 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I def wouldn’t “scrimp” on rockers for a .620 lift cam in a race car........ but you should be able to use something for less $$$ than the recommended HS rockers.
I test fit some Comp Pro Magnums at one point, I seem to remember them looking okay. I have some 270’s here...... I’ll check it again when I’m looking those heads over.
