Trick Flow 270 heads rocker arm choices? #2530602
08/02/18 06:41 PM
08/02/18 06:41 PM
junction city oregon
V
viperblue72 Offline OP
V
Is there a rocker that I can use that’s reasonably priced, such as the mancinis, or just a standard harland sharpe?
I am not gonna spend almost 1k for the cylinder head specific harland sharpes. Also I am only running a 274@050- .620 net lift w 1.6 rocker. Solid lifter.
Re: Trick Flow 270 heads rocker arm choices? [Re: viperblue72] #2530619
08/02/18 07:34 PM
08/02/18 07:34 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
I run the Crane Gold 1.5 on mine .
If you can still find them
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Trick Flow 270 heads rocker arm choices? [Re: viperblue72] #2530674
08/02/18 09:11 PM
08/02/18 09:11 PM
AndyF Offline
AndyF  Offline
I did all the work for you. 270 heads and 240 heads use the same rocker arms.
https://www.hotrod.com/articles/trying-find-extra-power-rocker-arm-testing/
Re: Trick Flow 270 heads rocker arm choices? [Re: viperblue72] #2530684
08/02/18 09:42 PM
08/02/18 09:42 PM
V
V
Thank you Andy.
Re: Trick Flow 270 heads rocker arm choices? [Re: viperblue72] #2530685
08/02/18 09:43 PM
08/02/18 09:43 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I def wouldn’t “scrimp” on rockers for a .620 lift cam in a race car........ but you should be able to use something for less $$$ than the recommended HS rockers.
I test fit some Comp Pro Magnums at one point, I seem to remember them looking okay.
I have some 270’s here...... I’ll check it again when I’m looking those heads over.
Re: Trick Flow 270 heads rocker arm choices? [Re: viperblue72] #2530687
08/02/18 09:46 PM
08/02/18 09:46 PM
V
V
Thank you fast68. I don’t plan on just scrimping but I don’t see the point in spending 1k when I’m only running a 400lb spring.
