Re: Carb experts with Hemi crossram intake.
[Re: maximus]
#2530682
08/02/18 09:38 PM
08/02/18 09:38 PM
Thumperdart
State of confusion
I have a Hemi with original magnesium cross-ram intake and new Holley cross-ram carbs. The car starts and idles perfect, good throttle response when car idle in park. The problem. If I give a quick jump of the throttle in gear it sometimes drops down to 600 rpm and comes back up to idle, most of the time it just falls off and stalls. Quick turn of the key and it restarts. What needs to be adjusted or looked at on the carbs to fix this problem? Idle mixture screws are all set at 1 1/2 turns out. Any input appreciated. Usually in my experience if it falls flat on it's face, it's lean, if it blubbers then dies then it's rich............
[Re: maximus]
#2530944
08/03/18 01:28 PM
08/03/18 01:28 PM
Posts: 4,210 New York
polyspheric
New York
Are the carbs specific to the engine & manifold? Do they have power valves?
Boffin Emeritus
[Re: maximus]
#2530986
08/03/18 02:43 PM
08/03/18 02:43 PM
Posts: 8,341 fredericksburg,va
cudaman1969
fredericksburg,va
I have a Hemi with original magnesium cross-ram intake and new Holley cross-ram carbs. The car starts and idles perfect, good throttle response when car idle in park. The problem. If I give a quick jump of the throttle in gear it sometimes drops down to 600 rpm and comes back up to idle, most of the time it just falls off and stalls. Quick turn of the key and it restarts. What needs to be adjusted or looked at on the carbs to fix this problem? Idle mixture screws are all set at 1 1/2 turns out. Any input appreciated. 600? What's your idle rpm? 600-750 is in the good range. Did you open up the throttle blade past the slot? Could be way past and using the main circuit instead of the idle. Are the back ones shut tight?
[Re: maximus]
#2531023
08/03/18 03:47 PM
08/03/18 03:47 PM
Posts: 25,951 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Idle mixture screws are all set at 1 1/2 turns out. Turn all the idle screws out (richen) a half-turn at a time to see if it improves.
[Re: John_Kunkel]
#2531051
08/03/18 04:32 PM
08/03/18 04:32 PM
Thumperdart
State of confusion
Idle mixture screws are all set at 1 1/2 turns out. Turn all the idle screws out (richen) a half-turn at a time to see if it improves. Good advice and where I usually start. Get a wide band and it's eye opening as to how much affect they have on idle, transition and cruise...........
