Re: High Volts
[Re: moparphilll]
#2530383
08/02/18 10:03 AM
08/02/18 10:03 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Yeah, there are two field wires to the alternator.
one of them, usually blue, goes tot eh feed side of the ballast and supplies a switched 12V to the alternator field.
The other, usually green, goes to the regulator and controls the return side of the field. This wire is shorted to ground, it should not be. Somewhere you pinched it in something, usually the valve cover.
Re: High Volts
[Re: moparphilll]
#2530409
08/02/18 11:22 AM
08/02/18 11:22 AM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
Not really the "return side" but the negative field. We are talking about direct current.
ballast is normally hot when engine is running
but as mentioned is true the green field could be somehow being grounded to chassis somewhere, either the wire or the brush itself.
Unplug reg and check if green wire terminal is shorted to body/engine. If so, unplug also the green wire on back of alt. If still, the is the green wire, if not, is the alternator... brush, isolator, or some small internall short on alt producing a full field issue
Re: High Volts
[Re: moparphilll]
#2530429
08/02/18 12:10 PM
08/02/18 12:10 PM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
I would be checking for a good ground on the voltage regulator and make sure that the battery voltage feedback is getting to the regulator.
Re: High Volts
[Re: moparphilll]
#2530437
08/02/18 12:32 PM
08/02/18 12:32 PM
RapidRobert
got another used alt you can swap in? On the current alt ohm the (2) male field lugs on the alt & ohm each one to the nearby case. if an issue on either test you might pull the brush assys & see if anything is grounded that shouldn't be.
Re: High Volts
[Re: markz528]
#2530577
08/02/18 05:54 PM
08/02/18 05:54 PM
Posts: 10,748 North Dakota
6PakBee
North Dakota
I would be checking for a good ground on the voltage regulator and make sure that the battery voltage feedback is getting to the regulator. This is good advice. If you look at the wiring diagram you can see that the voltage regulator should be grounded and takes the reference voltage from the key side of the ballast resistor. http://www.mopar1.us/charge.html
