High Volts #2530379
08/02/18 09:56 AM
08/02/18 09:56 AM
Fargo ND
moparphilll Offline OP
Fargo ND
Transplanted 440+6 into a 340 71 Challenger
Pegged Volt needle at mid RPMs
Shows 13Volts at Idle 18 volts at 2500RPM
? have swapped in 3 new voltage regs?
ballast resister HOT!
Ideas?
Re: High Volts [Re: moparphilll] #2530383
08/02/18 10:03 AM
08/02/18 10:03 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Yeah, there are two field wires to the alternator.
one of them, usually blue, goes tot eh feed side of the ballast and supplies a switched 12V to the alternator field.
The other, usually green, goes to the regulator and controls the return side of the field. This wire is shorted to ground, it should not be. Somewhere you pinched it in something, usually the valve cover.
Don't be the exception.
Re: High Volts [Re: moparphilll] #2530409
08/02/18 11:22 AM
08/02/18 11:22 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Not really the "return side" but the negative field. We are talking about direct current.
ballast is normally hot when engine is running
but as mentioned is true the green field could be somehow being grounded to chassis somewhere, either the wire or the brush itself.
Unplug reg and check if green wire terminal is shorted to body/engine. If so, unplug also the green wire on back of alt. If still, the is the green wire, if not, is the alternator... brush, isolator, or some small internall short on alt producing a full field issue
Re: High Volts [Re: moparphilll] #2530429
08/02/18 12:10 PM
08/02/18 12:10 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I would be checking for a good ground on the voltage regulator and make sure that the battery voltage feedback is getting to the regulator.
Re: High Volts [Re: moparphilll] #2530437
08/02/18 12:32 PM
08/02/18 12:32 PM
got another used alt you can swap in? On the current alt ohm the (2) male field lugs on the alt & ohm each one to the nearby case. if an issue on either test you might pull the brush assys & see if anything is grounded that shouldn't be.
Re: High Volts [Re: markz528] #2530577
08/02/18 05:54 PM
08/02/18 05:54 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
This is good advice. If you look at the wiring diagram you can see that the voltage regulator should be grounded and takes the reference voltage from the key side of the ballast resistor.
http://www.mopar1.us/charge.html
Re: High Volts [Re: moparphilll] #2530823
08/03/18 05:48 AM
08/03/18 05:48 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Agreed.
Re: High Volts [Re: moparphilll] #2530967
08/03/18 01:55 PM
08/03/18 01:55 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
If blue wire is disconnected it will go full charge. Should have battery voltage on blue wire at regulator plug.
