Page 1 of 3 1 2 3
Lets end some of the alcohol MYTHS #2530033
08/01/18 03:46 PM
08/01/18 03:46 PM
PA.
pittsburghracer Online work OP
"Little"John
pittsburghracer  Online Work OP
"Little"John
PA.
We've all heard it time and time again on how hard alcohol is to run and keep the water moisture out of it. I changed my oil "last year" at the beginner of September to get ready for all the long weekend races around Halloween. Last week 7-24-18 I changed it for the first time this year. My racing season ended the last week of October and started again the second week of April. I prefer Brad Penn as I have stuck with it through 3 different name changes at least over the last 44 years and have had zero issues with it. The steps are easy.
1. Get the jetting right. I have both O2's and EGT readings that I use.
2. Get heat in the engine (180 plus) 30 minutes before race time.
3. lean-out valve to build heat. I use a 1/2 inch ball valve
4. get it up to at least 165 degrees before starting your burn-out
5. After a pass shut off you fan, water pump, and open the lean out valve driving back to the pits after a pass.
6. Never ever just for the heck of it start your car during the week and rev it up to impress your buddies.
Pretty simple procedure that works. Here are some pictures from my oil change last week. I didn't even have to wipe out my valve covers or head drain-backs like I see guys doing that run pump gas or race gas.
Untitled by John Cadamore, on Flickr
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Lets end some of the alcohol MYTHS [Re: pittsburghracer] #2530056
08/01/18 04:30 PM
08/01/18 04:30 PM
New York
polyspheric Online content
polyspheric  Online Content
New York
You forgot Rule 0.: "be an adult who listens to good advice".
Boffin Emeritus
Re: Lets end some of the alcohol MYTHS [Re: polyspheric] #2530063
08/01/18 04:36 PM
08/01/18 04:36 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Alcohol Myth #1: Margaritas on the rocks are better than frozen.
Seriously, a Tequila Slushee rocks! punkrocka
Alcohol Myth #2: Margaritas without salt on the rim of the glass are totally acceptable.
Whaaaaaaaaaaaat?! NO SALT??? eek
We now return you to your regularly scheduled Moparts post. tonguue
Re: Lets end some of the alcohol MYTHS [Re: pittsburghracer] #2530078
08/01/18 04:54 PM
08/01/18 04:54 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I'm with Brad, although I prefer mine on the rocks with GOOD tequila I can rock a slushy when the time arises
Re: Lets end some of the alcohol MYTHS [Re: pittsburghracer] #2530084
08/01/18 05:08 PM
08/01/18 05:08 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
My blown alky hemi was so rich at idle/staging that we changed all 18 qts of oil after every run. We also changed the oil to cool the motor. The oil came out anyway after each run so we could replace the upper rod bearings so I could tune off of them for the next run.
Once in a while we would reuse the oil for a second run the next day if it looked good enough, most times not.
It took 18 qts in a 10 qt dragster pan to keep the pickup covered up for 5 seconds since 60 pounds of boost did not allow the oil to drain back very quick.
I had one crew guy who did my oil changes each run. It was up to him if we reused it the next day.
Re: Lets end some of the alcohol MYTHS [Re: pittsburghracer] #2530111
08/01/18 05:54 PM
08/01/18 05:54 PM
New York
New York
IIRC chamois used as a filter will remove water on each pass? Enough to make it worthwhile - IDK.
Boffin Emeritus
Re: Lets end some of the alcohol MYTHS [Re: pittsburghracer] #2530113
08/01/18 06:07 PM
08/01/18 06:07 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Fear the Kraken is my best alcohol advice.
Re: Lets end some of the alcohol MYTHS [Re: CMcAllister] #2530117
08/01/18 06:23 PM
08/01/18 06:23 PM
PA.
"Little"John
"Little"John
PA.
And some wonder why Mopar guys are stuck in the purple shaft days. Lol 😂
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Lets end some of the alcohol MYTHS [Re: pittsburghracer] #2530124
08/01/18 06:31 PM
08/01/18 06:31 PM
my own world
theraif Offline
theraif  Offline
my own world
bump6. Never ever just for the heck of it start your car during the week and rev it up to impress your buddies.
Re: Lets end some of the alcohol MYTHS [Re: pittsburghracer] #2530131
08/01/18 06:42 PM
08/01/18 06:42 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I like 1921 Tequila. As far as running in an engine ...very good advice!
Re: Lets end some of the alcohol MYTHS [Re: quickd100] #2530150
08/01/18 07:19 PM
08/01/18 07:19 PM
oregon
greendart408 Offline
oregon
I agree with Pittsburg, only thing I did diff is added a star vac pump. I ran injected with 2 toilets on a tr and another motor with a single toilet on a 4bbl intake. Loved the injection, I ran that stuff on a w5 combo and a 360-1 combo for 10 or so yrs. Both ran well, I would still be running it if I wouldn't have switched to a f2, e85, w8 combo.
Re: Lets end some of the alcohol MYTHS [Re: polyspheric] #2530181
08/01/18 08:41 PM
08/01/18 08:41 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Sham-WOW. 😁
Re: Lets end some of the alcohol MYTHS [Re: theraif] #2530185
08/01/18 08:54 PM
08/01/18 08:54 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
That usually happens after the Margareta's LMBO smile
Re: Lets end some of the alcohol MYTHS [Re: pittsburghracer] #2530192
08/01/18 09:18 PM
08/01/18 09:18 PM
P
Porter67 Offline
Porter67  Offline
P
Your just a "special" guy, thats part of it.
Re: Lets end some of the alcohol MYTHS [Re: Porter67] #2530200
08/01/18 09:26 PM
08/01/18 09:26 PM
PA.
"Little"John
"Little"John
PA.
Not sure what you mean by that but I’m all ears. Let it out
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Lets end some of the alcohol MYTHS [Re: pittsburghracer] #2530219
08/01/18 10:12 PM
08/01/18 10:12 PM
P
Porter67 Offline
Porter67  Offline
P
Just an off the cuff comment after coming in from finding the cat I buried got dug up and drug off by some foxes or coyotes.
Ive never bought into myths on fuels myself, ive had zero problems many mention with pump or race gas, carbs, fuel lines, ect.
So I dont go for the common myths on alky either, used to run a pull tractor on it and dont recall any big pitfalls then except things staying cold and making ice.
I guess "special" will be banned form use soon.
Re: Lets end some of the alcohol MYTHS [Re: pittsburghracer] #2530223
08/01/18 10:20 PM
08/01/18 10:20 PM
Nevada
merpar Offline
merpar  Offline
Nevada
Pittsburgh, Best advice I've seen on here in quite a while.
Re: Lets end some of the alcohol MYTHS [Re: pittsburghracer] #2530233
08/01/18 10:39 PM
08/01/18 10:39 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
How about a PTO? You can start the car, whack the throttle and some daquiri's at the same time! haha
Re: Lets end some of the alcohol MYTHS [Re: Dave Hall] #2530238
08/01/18 10:51 PM
08/01/18 10:51 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
What about fuel system storage corrosion?
Re: Lets end some of the alcohol MYTHS [Re: pittsburghracer] #2530239
08/01/18 10:51 PM
08/01/18 10:51 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I’m certainly too lazy to ever entertain the idea, but how many O2 sensors and egt’s along with location.
Page 1 of 3 1 2 3
